PIONEER BD-RW BDR-S13U 1.04 stopped working?
jcfrosty
#1 Post by jcfrosty » Mon Apr 27, 2026 4:49 pm
I know this drive had firmware that LibreDrive didn't originally support, but I have been using it for a while regardless. I had it gathering dust this last year because there haven't been many movies I was interested in buying and putting on my server, but some movies my kids were interested in came out and decided to get them and put the on the server. During me catching up I find 1yr is a long time for MakeMKV and evidently more Pioneer drives are now supported since PIONEER got out of the optical drive game?
So I hooked my my external OWC enclosure w/ Pioneer BDR-S13U 1.04 only to find. NO, it doesn't work anymore AT ALL! Its worked fine for a couple years before it was left unused for a year. Figured maybe the cable went bad and swapped cables to find no changes. Now, I do understand drives can go bad just being idle, but I'm struggling to accept this could be the case for this drive in particular.
Are there any suggestions on how to troubleshoot this, as it never gets past these errors? reboot/cold boot power cycle of both laptop and drive with unplug/replug, replaced cable, all to no avail.
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..00724B57349177155037958A9E650B60EFF to device 'SG:dev_21:0'
Error 'Scsi error - HARDWARE ERROR:INTERNAL TARGET FAILURE' occurred while issuing SCSI command A30..00200740100720..041241F2982037352289EE14188F572A031 to device 'SG:dev_21:0'
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S13U
Revision: 1.04
Serial number: CDDL300398UC
Firmware date: 2022-12-12
Highest AACS version: 82
Drive platform: RS9201
Firmware name: PIONEER BDR-213T
Firmware version: 1.04/ID43
jcfrosty
Re: PIONEER BD-RW BDR-S13U 1.04 stopped working?
#2 Post by jcfrosty » Mon Apr 27, 2026 5:07 pm
So far it appears either my enclosure has failed or the disc drive has failed. This is super disappointing.
[ 2732.466481] usb 2-2.1: new SuperSpeed USB device number 3 using xhci_hcd
[ 2732.477822] usb 2-2.1: New USB device found, idVendor=1e91, idProduct=de2c, bcdDevice= 1.00
[ 2732.477837] usb 2-2.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 2732.477844] usb 2-2.1: Product: Mercury Pro Optical
[ 2732.477849] usb 2-2.1: Manufacturer: Other World Computing
[ 2732.477854] usb 2-2.1: SerialNumber: 210524880677
[ 2732.478446] usb-storage 2-2.1:1.0: USB Mass Storage device detected
[ 2732.478959] scsi host0: usb-storage 2-2.1:1.0
[ 2733.532532] scsi 0:0:0:0: CD-ROM            PIONEER  BD-RW   BDR-S13U 1.04 PQ: 0 ANSI: 0
[ 2733.545030] sr 0:0:0:0: [sr0] scsi3-mmc drive: 204x/204x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2733.564299] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 2733.564611] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 3174.184071] UDF-fs: INFO Mounting volume 'MOANA_2', timestamp 2025/01/15 17:47 (1000)
[ 3209.070033] usb 2-2.1: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3209.081861] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_TIME_OUT driverbyte=DRIVER_OK cmd_age=30s
[ 3209.081872] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 02 ad 00 00 40 00
[ 3209.081877] I/O error, dev sr0, sector 2740 op 0x0:(READ) flags 0x80700 phys_seg 28 prio class 2
[ 3243.375343] usb 2-2.1: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3243.401542] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=30s
[ 3243.401548] sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[ 3243.401551] sr 0:0:0:0: [sr0] tag#0 Add. Sense: Read of scrambled sector without authentication
[ 3243.401554] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 02 cf 00 00 02 00
[ 3243.401556] I/O error, dev sr0, sector 2880 op 0x0:(READ) flags 0x800000 phys_seg 1 prio class 2
[ 3274.607049] usb 2-2.1: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3274.631850] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=30s
[ 3274.631856] sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[ 3274.631859] sr 0:0:0:0: [sr0] tag#0 Add. Sense: Read of scrambled sector without authentication
[ 3274.631862] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 02 cf 00 00 02 00
[ 3274.631864] I/O error, dev sr0, sector 2880 op 0x0:(READ) flags 0x800000 phys_seg 1 prio class 2
[ 3305.839476] usb 2-2.1: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3305.866175] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=30s
[ 3305.866181] sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[ 3305.866184] sr 0:0:0:0: [sr0] tag#0 Add. Sense: Read of scrambled sector without authentication
[ 3305.866187] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 02 cf 00 00 02 00
[ 3305.866189] I/O error, dev sr0, sector 2880 op 0x0:(READ) flags 0x800000 phys_seg 1 prio class 2
[ 3336.049254] usb 2-2.1: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3336.060918] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_TIME_OUT driverbyte=DRIVER_OK cmd_age=30s
[ 3336.060931] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 10 01 9b 00 00 40 00
[ 3336.060937] I/O error, dev sr0, sector 4195948 op 0x0:(READ) flags 0x80700 phys_seg 16 prio class 2
[ 3367.277794] usb 2-2.1: reset SuperSpeed USB device number 3 using xhci_hcd
[ 3367.305058] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=30s
[ 3367.305064] sr 0:0:0:0: [sr0] tag#0 Sense Key : Illegal Request [current]
[ 3367.305067] sr 0:0:0:0: [sr0] tag#0 Add. Sense: Read of scrambled sector without authentication
[ 3367.305070] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 00 02 cf 00 00 02 00
[ 3367.305072] I/O error, dev sr0, sector 2880 op 0x0:(READ) flags 0x800000 phys_seg 1 prio class 2
#3 Post by MartyMcNuts » Mon Apr 27, 2026 10:30 pm
jcfrosty wrote: Mon Apr 27, 2026 5:07 pm So far it appears either my enclosure has failed or the disc drive has failed. This is super disappointing.
So, remove the drive from the enclosure and either:
  • install internally and connect to SATA if possible
  • use an AC powered SATA to USB adapter (check the recommended list in the Ultimate UHD Guide 2026)
This will tell you if the issue is the drive or the enclosure.
tomty89
#4 Post by tomty89 » Tue Apr 28, 2026 6:59 am
I wonder if this has something to do with "bus encryption", since the disc you have been testing with(?) is apparently one of the latest (re-)releases. Have you tested with a disc that you successfully ripped in the past?
This somewhat sounds like MakeMKV did not actually / successfully / fully enabled LibreDrive. Could be the enclosure. Could also be a bug / regression in MakeMKV. (Is 1.18.3 the version of MakeMKV that you have been testing with btw?) Could also be irrelevant (as they seem to be trigger by automounting in your system; i.e. before MakeMKV enabling the LibreDrive / disabling bus encryption).
At what stage did you saw those? When you "open" the disc? Or at some point during ripping?
audiotechnica
#5 Post by audiotechnica » Sat May 02, 2026 2:40 pm
I have a BDR-211UBK with firmware 1.54 that won't rip 4K discs in MakeMKV 1.18.3 even though it shows that LibreDrive is enabled - it errors out with "Couldn't read AACS VID from disc." Tried different enclosures (other PIoneer drives work fine in those enclosures) and also connecting directly to SATA.
I also have a BDR-212UBK with firmware 1.05 that rips 4K discs perfectly fine in MakeMKV 1.18.3. Feels like a MakeMKV bug to me, since the forum says all Pioneer drives work with LibreDrive, even those upgraded to the latest firmware.
#6 Post by Billycar11 » Sat May 02, 2026 2:56 pm
For fun you could try and update the s13 to the newest and see if it works then
If there is a bug related to this specific version for some reason
jcfrosty
#7 Post by jcfrosty » Tue May 19, 2026 6:10 pm
tomty89 wrote: Tue Apr 28, 2026 6:59 am I wonder if this has something to do with "bus encryption", since the disc you have been testing with(?) is apparently one of the latest (re-)releases. Have you tested with a disc that you successfully ripped in the past?
Yeah, I ripped the disc just fine using BDR-XS07S. I will say the video had something going on though causing VLC to not want to load sometimes and would throw some errors when playing and PLEX refused to recognize it. I transcoded to HEVC (h265) and copied subs and audio, now the transcoded version works fine and PLEX recognizes it just fine. Definitely something strange about that specific disc.
As for the errors, they kicked off after trying to load the disc to show chapters for ripping.
jcfrosty
#8 Post by jcfrosty » Tue May 19, 2026 6:11 pm
Billycar11 wrote: Sat May 02, 2026 2:56 pm For fun you could try and update the s13 to the newest and see if it works then
Good idea. it definitely wouldn't make it any worse, so no harm in trying.
