Can someone help me recover the drive and then which is the right one to flash it to
I am hoping the drive can be salvaged
This is the drive I am using and the screen I am at
Any help would be greatly appreciated
Whenever I try flash it all I get is a command error messagezittrig wrote:Ok, there're two possibilities in my opinion:
1. Get the drive out for a look to the modell. The save way.
or
2. Blind trying the recovery mode with the SDF Flasher. In the first drop down menu use the BU40N firmware from the first flash and in the second drop down use the WH16NS60 1.02MK. In the web I found information about someone who found a BH16NS58 in the Buffalo BRXL-16U3. That drive is flashable.
If you had of used my all you need firmware pack available from the same post where SDFtool flasher is downloaded from you would not have this issue as the firmware is split into slim and desktop folders.Sluggo080976 wrote: ↑Sun Apr 26, 2026 10:13 pmWhenever I try flash it all I get is a command error messagezittrig wrote:Ok, there're two possibilities in my opinion:
or
I truly don’t know how to flash it back but I truly appreciate your help
Take the disc out of the drive!!!Sluggo080976 wrote: ↑Mon Apr 27, 2026 2:32 am
When I try to flash I get this message now
