PM sent.pradogx wrote: Fri Jan 30, 2026 3:22 am Coopervid,
Can you help me out with this as well? Much appreciated!
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: xxxxxxxxxxxx
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Another request!
OS device name: E:
Revision: 1.14
Serial number: XXXXXXXXXX
Highest AACS version: 77
OS device name: E:
Revision: 1.14
Email me that drive info section see below for emailIdaho121 wrote: Sat Feb 07, 2026 9:16 pm Another request!
OS device name: E:
Revision: 1.14
rob_levine
Hi - another request. In this case, I've already flashed to 1.03 but have two 4k UHD Blu-Rays, neither of which work. Normal Blu-Rays working fine.
OS device name: G:
Product: BD-RE BU40N
Revision: 1.03
Serial number:
Highest AACS version: 82
Firmware version: 1.03
OS device name: G:
Revision: 1.03
Serial number:
You need to provide some info about why they are not working for UHD. Perhaps copy and paste the log window text when attempting a UHD rip?rob_levine wrote: Fri Apr 24, 2026 9:17 am Hi - another request. In this case, I've already flashed to 1.03 but have two 4k UHD Blu-Rays, neither of which work. Normal Blu-Rays working fine.
OS device name: G:
Revision: 1.03
Serial number:
rob_levine
Thanks for the quick reply. Sure - info and logs attached for both the failing discs.
- DISK 2 - ANDOR.txt
- (66.58 KiB) Downloaded 1407 times
- DISK 1 - INCEPTION.txt
- (66.61 KiB) Downloaded 1460 times
Have you tried power cycling your drive?rob_levine wrote: Sat Apr 25, 2026 9:51 am Thanks for the quick reply. Sure - info and logs attached for both the failing discs.
I have problems with a 43890 Verbatim USB Slim Writer (ans I'm new to subjects UHD with makemkv):
Laufwerksinformation
OS-Gerätename: /dev/sr2
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer:XXXXXXXXXXXXXXx
Firmware-Datum: 2020-06-15
It run's fine without UHD.I need to unlock, if possible.
It's not able to fully dump the firmware (and has no rawflash option):
makemkvcon f -d /dev/sr2 help
Pioneer firmware module v1.20
Commands:
dump [auto|full] dumps firmware image
dump full - dumps full rom image (if not disabled in firmware)
dump auto - dumps full image if possible, info data otherwise
speed get - prints current speed mode setting
speed set MODE - writes new default speed mode to EEPROM
What can be done in this case, can you please comment this.
Kind regards
Produzent: PIONEER
Revision: 1.14
Commands:
Kind regards
Yes it can do UHD but not with the flashing tool you are asking aboutcoconut26 wrote: Sun Jun 07, 2026 10:01 am Hi,
Produzent: PIONEER
Revision: 1.14
Commands:
Kind regards
sure email me that info and all others email me
no need to post your info here publicly just reach out to me directly
see below for email
