the ten commandments 1956
methuselah
Post by methuselah »
i'm trying to copy two different copies of the ten commandments and ben hur and keep getting errors. any help would be greatly appreciated. i've cleaned the discs. there are no obvious things on the disc. i'm using a dell latitude e5450 with a pioneer bdp-x509 drive that's attached with two usb cables to the pc. running windows 11.
here are my errors. i keep getting. any help to fix would be greatly appreciated.
what are these errors and how can i get around them?
Saving 1 titles into directory E:/Movies/Ben-Hur (1959)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00072.m2ts' at offset '8508801024'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '8508801024'
DEBUG: Code 3221225628 at mSHv1hk}.MpL;_ZYj<:213131502
Re: the ten commandments 1956
The errors you are receiving are consistent with the drive running out of power at high speed. What drive, and how is it powered?
