List of DVD/BluRay that haven't worked
Neycroir
Re: List of DVD/BluRay that haven't worked
#46 Post by Neycroir » Tue Nov 10, 2009 1:35 pm
Futurama Season 2 Disc 2 & 4 doesn't work. CelllWallk-Algorithm failed, then makeMKV 1.4.8. chrashs.
AnyDVD is activated, DVDs are playing fine. SmartRipper has no problem with those discs.
slade37
#47 Post by slade37 » Wed Nov 11, 2009 2:34 am
Star Trek The Original Series - Season 1 Blu-Ray - US Release.
It failed to save the MKV files for the episodes. No trouble with the extras that it could read. The episodes have multiple angles (original and new CGI effects). That's the only unique thing I can think of about this title.
This is not part of the box set with all 3 seasons. I know season 3 and the box set hasn't been released at the time of this writing. I'm saying that for anyone reading this months from now.
kevinbal
#48 Post by kevinbal » Wed Nov 11, 2009 5:02 pm
The Duchess, US BD disc. Fatal Error causes program to quit part way through encode of main title.
Debug log started at Wed Nov 11 16:07:22 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
001014:000000:0000 MakeMKV v1.4.8 beta darwin(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as /Users/kevinbal/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 0 at %$K'7k/|wNr!5t\jn#?F9B<s@CM:121264878
003010:000000:0000 Using direct disc access mode
001012:000000:0020 FAILURE: Code 2 at Y89?Uipt6*g-w=I?:213135251
SD=ZeNorYGBh1C18w8cABC5yDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIAWlwNXA==
001012:000000:0020 FAILURE: Code 4294967276 at 2H5&RkBUsAzq~i\L~b:29394068
SD=ZeNr7wMDMqFv4ho8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBascNjw==
001012:000000:0020 FAILURE: Code 4294967276 at 2H5&RkBUsAzq~i\L~b:121262601
001012:000000:0020 FAILURE: Code 4294967276 at 2H5&RkBUsAzq~i\L~b:29394597
SD=ZeNr7wMDMqH9Ii48BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBUfYNIA==
SD=ZeNorYGBm1D+kxccABKJMDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIAMi0MoQ==
SD=ZeNr7wMDMqDPfmo8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBTQsNCw==
SD=ZeNorYGBh1JlvzccABC5yDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIAPKAM2A==
SD=ZeNorYGBm1JlvzccABKJMDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIALUIMjA==
SD=ZeNr7wMDMqJnLy8cABIKsDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIANmUMqA==
SD=ZeNr7wMDMaOZ0kI8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBWFANPg==
SD=ZeNr7wMDMaN72go8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBcQ4Nqg==
DISCID=76A4F93483407E0488C28E0E7223F2168CE30CDF
003316:000000:0000 Only extracting AC3 core audio from stream #1 of type 'DD True HD audio' in file 00000.m2ts
003313:000000:0000 File 00000.mpls was added as title #0
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00004
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00005
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00006
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00007
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00008
003020:000000:0000 Title #00002.mpls has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00022
003020:000000:0000 Title #00001.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00010.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00011.m2ts was added as title #1
003313:000000:0000 File 00012.m2ts was added as title #2
003020:000000:0000 Title #00013.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00014.m2ts was added as title #3
SD=ZeNorYGBhVPvUwMcABC5yDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIAXfsNag==
001012:000000:0020 FAILURE: Code 4294967276 at @5_r6=!rR4?0;u;":121267270
SD=ZeNr7wMDMqPYpgY8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBZyYNfQ==
SD=ZeNorYGBmVPuUwMcABKJMDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIAR10M/g==
SD=ZeNorYGBhVPuUwMcABC5yDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIAVrsNSg==
SD=ZeNorYGBmVPvUwMcABKJMDHBwi0Fi8pJkBgZGKF+GUWKyQzoDw38gCPliARbzANIATp0NHg==
001012:000000:0020 FAILURE: Code 0 at @5_r6=!rR4?0;u;":213134837
002007:000000:0000 Read error. File="<n/a>" Info=""
001012:000000:0020 FAILURE: Code 0 at )MSesRdk.'R(!BY%]w<E:121262509
001012:000000:0020 FAILURE: Code 0 at [iead6MKH~pEx6+G,Ifo:121262049
001012:000000:0020 FAILURE: Code 0 at )MSesRdk.'R(!BY%]w<E:121262164
001012:000000:0020 FAILURE: Code 31 at )MSesRdk.'R(!BY%]w<E:213129639
001012:000000:0020 FAILURE: Code 0 at Ki[$9xEvae-@2&CECQJW_:121264326
001003:000000:0020 DBG ASSERT: q{=2EP2hX#O|)vNU$['MeSiaw\+qX5hhu at ~t!n'l%<]8E`UCL9+_RsAib6h:121262026
003313:000000:0000 File 00015.m2ts was added as title #4
SD=ZeNr7wMDMqPapgY8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBbmYNnQ==
003313:000000:0000 File 00017.m2ts was added as title #5
003020:000000:0000 Title #00018.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
SD=ZeNr7wMDMaHRUgY8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBURcNHA==
001012:000000:0020 FAILURE: Code 607 at )MSesRdk.'R(!BY%]w<E:213129639
003313:000000:0000 File 00022.m2ts was added as title #6
003313:000000:0000 File 00023.m2ts was added as title #7
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory /Users/kevinbal/Desktop
SD=ZeNr7wMDMIC75gI8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBTmINFA==
SD=ZeNr7wMDMIC77gI8BCARZGeDgFoPE5CXJDAyMUL4Mo8Rkh3QGhv9AEPLFAizmAaQBT04NGA==
001012:000000:0020 FAILURE: Code 0 at [iead6MKH~pEx6+G,Ifo:213130053
001012:000000:0020 FAILURE: Code 249408 at )MSesRdk.'R(!BY%]w<E:213129639
alexander
#49 Post by alexander » Sun Nov 15, 2009 6:37 pm
JonnyD
BD copy on disc with no protection
makemkv 1.4.8. beta x86 Vista SP1
-------------- Output begin ---------------
MakeMKV v1.4.8 beta win(x86-release) started
Opening files on harddrive at I:/HD Movies/JonnyD/
AACS directory not present, assuming unencrypted disc
Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00000.m2ts
Saving 1 titles into directory C:/HD movies
Failed to save title 0 to file C:/HD movies/title00.mkv
0 titles saved, 1 failed
------------------ Output end ----------------
Terminator
BD copy on disk with no protection
Opening files on harddrive at I:/HD Movies/The.Terminator/
File 00003.mpls was added as title #1
File 00016.mpls was added as title #2
Title 00018.mpls is equal to title 00003.mpls and was skipped
Title 00019.mpls is equal to title 00003.mpls and was skipped
Title 00020.mpls is equal to title 00003.mpls and was skipped
Title 00021.mpls is equal to title 00003.mpls and was skipped
Title 00022.mpls is equal to title 00003.mpls and was skipped
Title 00023.mpls is equal to title 00003.mpls and was skipped
File 00024.mpls was added as title #3
File 00002.m2ts was added as title #4
File 00003.m2ts was added as title #5
Title #00005.m2ts has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.m2ts was added as title #6
Title #00007.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
1 titles saved
Output file is in place but contains a darkness only.
Mediainfo says about that
----------- Mediainfo begin -------------------------
General
Complete name : C:\HD movies\title02.mkv
Format : Matroska
File size : 18.0 GiB
Duration : 1h 47mn
Overall bit rate : 24.0 Mbps
Encoded date : UTC 2009-11-15 18:05:15
Writing application : MakeMKV v1.4.8 beta win(x86-release)
Writing library : libmakemkv v1.4.8 beta (0.7.7/0.8.1) win(x86-release)
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 1h 47mn
Bit rate mode : Variable
Bit rate : 13.7 Mbps
Nominal bit rate : 30.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.275
Stream size : 10.2 GiB (57%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 47mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 491 MiB (3%)
Title : 3/2+1
Language : Russian
------------------------ Mediainfo end --------------
kevinbal
#50 Post by kevinbal » Wed Nov 25, 2009 11:01 am
The Wrestler, US BD+
Debug log started at Wed Nov 25 10:38:48 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
003326:000000:0000 Loaded 203 SVQ file(s)
003334:000000:0000 Processing BD+ code, please be patient - this may take up to few minutes
003330:000000:0000 Processing BD+ code using disc-specific SVQ from dscombo.svq
003336:000000:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=C6489B97A60491A76AC8EC92F52C2F4DC68E312C
003020:000000:0000 Title #00001.mpls has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00002.m2ts
003313:000000:0000 File 00002.mpls was added as title #0
003020:000000:0000 Title #00003.mpls has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00101
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00102
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00103
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00104
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00105
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00106
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00107
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00108
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00109
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00110
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00111
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00112
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00113
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00114
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00115
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00116
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00117
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00118
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00119
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00120
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00121
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00122
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00123
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00124
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00125
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00126
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00127
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00128
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00129
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00130
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00131
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00132
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00133
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00134
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00135
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00136
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00137
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00138
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00139
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00140
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00141
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00142
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00143
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00144
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00145
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00146
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00147
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00148
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00149
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00150
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00151
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00152
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00153
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00154
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00155
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00156
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00158
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00159
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00160
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00161
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00162
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00163
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00164
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00165
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00166
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00167
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00168
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00169
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00170
003020:000000:0000 Title #00001.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00003.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00100.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00157.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00300.m2ts was added as title #1
003313:000000:0000 File 00301.m2ts was added as title #2
003313:000000:0000 File 00302.m2ts was added as title #3
003313:000000:0000 File 00303.m2ts was added as title #4
003313:000000:0000 File 00304.m2ts was added as title #5
003020:000000:0000 Title #00305.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00306.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:000000:0000 Saving 6 titles into directory /Users/kevinbal/Desktop
SD=ZeNr7wMDM4P3GgY8BCARZQeT//wn/LRhuOUycsiSZgYGRAQJkHCdOcUgHyf7/H/LFAizmAaQBMkIShA==
SD=ZeNr7wMDM4P1OgY8BCARZQeT//wn/LRhuOUycsiSZgYGRAQJkHCdOcUgHyf7/H/LFAizmAaQBK3gSZg==
001012:000000:0020 FAILURE: Code 3467296 at )MSesRdk.'R(!BY%]w<E:213129639
001012:000000:0020 FAILURE: Code 0 at Ki[$9xEvae-@2&CECQJW_:121264211
kevinbal
#51 Post by kevinbal » Sat Nov 28, 2009 4:01 pm
Coraline, US BD
Debug log started at Sat Nov 28 15:23:17 2009 , written by MakeMKV v1.4.8 beta darwin(x86-release)
DISCID=78440B0E643C6BCC3DCD1C86CF8365546D5F3FDE
003020:000000:0000 Title #00099.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00009
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00010.m2ts
003308:000000:0000 Stream #12 of type 'DTS-HD secondary audio' in file 00010.m2ts was skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00502
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00500
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00083.m2ts
003313:000000:0000 File 00002.mpls was added as title #1
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00250
003313:000000:0000 File 00010.mpls was added as title #2
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00040
003313:000000:0000 File 00151.mpls was added as title #3
003313:000000:0000 File 00152.mpls was added as title #4
003314:000000:0000 Title 00153.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00154.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00155.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00156.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00157.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00158.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00159.mpls is equal to title 00152.mpls and was skipped
003314:000000:0000 Title 00160.mpls is equal to title 00152.mpls and was skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00060
003020:000000:0000 Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00011.m2ts was added as title #5
003020:000000:0000 Title #00050.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00056.m2ts was added as title #6
003020:000000:0000 Title #00061.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00062.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00076.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00078.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00080.m2ts was added as title #7
003313:000000:0000 File 00081.m2ts was added as title #8
003020:000000:0000 Title #00084.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003314:000000:0000 Title 00151.mpls is equal to title 00152.mpls and was skipped
SD=ZeNr7wMDM0MDBwMcABIKsDHBwy2HilCXJDAyMUL6M48QpDukMDP+BIOSLBVjMA0gDAFxpDgA=
SD=ZeNr7wMDMsIj/AR8DEAiyMsDBLYeJU5YkMzAwQvkyjhOnOKQzMPwHgpAvFmAxDyANAJi+Dwk=
001012:000000:0020 FAILURE: Code 7687488 at )MSesRdk.'R(!BY%]w<E:213129639
farmwald
#52 Post by farmwald » Wed Dec 02, 2009 4:37 am
Blu-Ray Serenity still fails. The error message is:
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 0 to file R:/Video/MakeMKV/Serenity/title00.mkv
I'm happy to post log if it helps debug problem.
farmwald
#53 Post by farmwald » Wed Dec 02, 2009 4:39 am
Just to be clear, Serenity fails with MakeMKV 1.4.9
Andie
#54 Post by Andie » Wed Dec 02, 2009 1:42 pm
Andie wrote:Friday "New Line Platinum Series" DVD. It reads a few tracks none of which are the movie.
Tried it with the new version (1.4.9) and still no good. Reads a few tracks all less than 3 mins. Here's the log:
Debug log started at Wed Dec 02 13:37:39 2009 , written by MakeMKV v1.4.9 beta win(x64-release)
001014:000000:0000 MakeMKV v1.4.9 beta win(x64-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Andie/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 2 at /CW2w&;*mYHK*iE#:213135251
SD=ZeNorYGBlAAIuEJHPzAAH/3EAZgYOsDwLQwNYJwDkGxlu
001012:000000:0020 FAILURE: Code 4294967276 at kl|kZ#^s6U7<Ho6rGH:29394045
SD=ZeNorYGBlAAIuEJHPzIATMDJwNWATBwBCSQF9
SD=ZeNorYGBlAAIuEJHPzAAHWRNAJCODiRuEzoDydV0hdHc/hAYAknUE7w==
SD=ZeNorYGBlAAIuEJHPzAAHjAw8BxiwgASjWawNv/7/T7jnC6YBnK8LcA==
001012:000000:0020 FAILURE: Code 4294967276 at kl|kZ#^s6U7<Ho6rGH:213130697
001012:000000:0020 FAILURE: Code 4294967276 at kl|kZ#^s6U7<Ho6rGH:121263406
001012:000000:0020 FAILURE: Code 134219780 at R`_f-3_:6Ts4VPGp;v-0:213130490
001012:000000:0020 FAILURE: Code 0 at R`_f-3_:6Ts4VPGp;v-0:213131962
003025:000000:0000 Drive BD-ROM ATAPI iHOS104 WL0B has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
003017:000000:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003036:000000:0000 Title #0 was added (1 cell(s), 0:03:52)
003036:000000:0000 Title #1 was added (1 cell(s), 0:05:12)
003020:000000:0000 Title #2 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:000000:0000 Cell 1 was discarded (structure protection?)
003037:000000:0000 Title #3 (0:00:00) was skipped
003016:000000:0000 Title 3 in VTS 1 is a Multi-PGC title
003015:000000:0000 Title #4 was skipped
003020:000000:0000 Title #5 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #6 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001012:000000:0020 FAILURE: Code 0 at L2;LP;SXgkdC#.`%<z:29393976
003032:000000:0000 CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003047:000000:0000 Fake cells occupy 91% of the title - assuming fake title
003037:000000:0000 Title #7 (0:00:00) was skipped
003020:000000:0000 Title #8 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003047:000000:0000 Fake cells occupy 83% of the title - assuming fake title
003037:000000:0000 Title #9 (0:00:00) was skipped
003047:000000:0000 Fake cells occupy 92% of the title - assuming fake title
003037:000000:0000 Title #10 (0:00:00) was skipped
003020:000000:0000 Title #11 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #12 was added (1 cell(s), 0:02:46)
003036:000000:0000 Title #13 was added (1 cell(s), 0:02:20)
003020:000000:0000 Title #14 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003016:000000:0000 Title 6 in VTS 1 is a Multi-PGC title
003015:000000:0000 Title #15 was skipped
Is it title 3? And my BD-ROM keeps giving me that error even though I set it up for region 1. What does that mean exactly? Ditto with Geisha. The only 2 DVDs in my collection that won't rip! :lol:
Andie
#55 Post by Andie » Wed Dec 02, 2009 10:36 pm
Got another one. The Simpsons: The Complete Third Season DVD #3 does not completely rip. It was successful in ripping Title00-01 and 04-05. Titles 02-03 will not read/rip. Code:
Debug log started at Wed Dec 02 22:19:40 2009 , written by MakeMKV v1.4.9 beta win(x64-release)
003028:000000:0000 Cell 8 was discarded (structure protection?)
003036:000000:0000 Title #0 was added (7 cell(s), 0:22:59)
003028:000000:0000 Cell 10 was discarded (structure protection?)
003036:000000:0000 Title #1 was added (9 cell(s), 0:22:59)
003028:000000:0000 Cell 9 was discarded (structure protection?)
SD=ZeNorYGBmAAIuECHIygAHEhYMrA2//v9PeP2EDUQLQPkN29zZQTQjAyMTSB0Ax64S0w==
SD=ZeNorYGBmAAIuECHIygAHRQyJDLkMCgxuDJkMOQypDMUMMQzODPlAsVwgmQeXAQC9sQfn
SD=ZeNorYGBmAAIuECHIygAHuQypDEYMMQwBDEUM+QzpQDIRKKbA4MaQyZADlCsGyjkDZQC9dwft
SD=ZeNorYGBmAAIuECHIykA0YGTgOcDAIMoAACfhAXY=
001012:000000:0020 FAILURE: Code 0 at <Wp9znyKCw'L~?+S':121263061
SD=ZeNorYGBmAAIuECHIygAHKQyZDMUM2QxhDPkMOQylDLkMqQxGDDEMAQxFQJF0IJkIFFNgAADKOQg9
001012:000000:0020 FAILURE: Code 0 at <Wp9znyKCw'L~?+S':121263015
003053:000000:0000 Title #2 declared length is 0:22:56 while its real length is 0:12:07 - assuming fake title
003036:000000:0000 Title #3 was added (9 cell(s), 0:22:56)
003028:000000:0000 Cell 7 was discarded (structure protection?)
003036:000000:0000 Title #4 was added (6 cell(s), 0:22:58)
003036:000000:0000 Title #5 was added (8 cell(s), 0:22:58)
003020:000000:0000 Title #6 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003016:000000:0000 Title 7 in VTS 1 is a Multi-PGC title
003015:000000:0000 Title #7 was skipped
003015:000000:0000 Title #8 was skipped
003020:000000:0000 Title #9 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003015:000000:0000 Title #10 was skipped
003020:000000:0000 Title #11 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003016:000000:0000 Title 4 in VTS 1 is a Multi-PGC title
003015:000000:0000 Title #12 was skipped
003036:000000:0000 Title #2 was added (8 cell(s), 0:22:56)
005014:000000:0000 Saving 2 titles into directory C:/Users/Andie/Desktop
001012:000000:0020 FAILURE: Code 4294967276 at s5k'Ka4jU!deW6/L:213135665
001012:000000:0020 FAILURE: Code 0 at s5k'Ka4jU!deW6/L:29398691
SD=ZeNorYGBmAAIuECHIykAQ/IcCGB8Ah0MIjA==
SD=ZeNorYGBmAAIuECHIygAHmQzJDKkMMQweDIkMRQwpQJjJUMyQzRDGkM+Qw1DKkAuUNQLKAwDHbQhR
002010:000000:0000 Read error. Sector=1819697
001012:000000:0020 FAILURE: Code 0 at adI9Ob7ELzK"MC.yGwP:213131939
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:29393516
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:213129639
001012:000000:0020 FAILURE: Code 0 at 44?G=bdrG^_VQ86[Dc%*j:121264326
001012:000000:0020 FAILURE: Code 0 at G>4qk)o,"*Ru*\8-i0=:121261980
001012:000000:0020 FAILURE: Code 0 at G>4qk)o,"*Ru*\8-i0=:213131502
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 2 to file C:/Users/Andie/Desktop/title02.mkv
SD=ZeNorYGBmAAIuECHIykAQCER+Zmv49f+/LPO/UyA+AGYEB1Y=
SD=ZeNorYGBmAAIuECHIyoAC9rAwMMxmZGBgA+KCE1fBChlBRAMbR0Eko4CXSMgBAJEPBuI=
SD=ZeNorYGBmAAIuECHIygAHjGCyoYUBEwggcwBGowGp
002010:000000:0000 Read error. Sector=2005002
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:121262509
001012:000000:0020 FAILURE: Code 0 at adI9Ob7ELzK"MC.yGwP:29393470
001012:000000:0020 FAILURE: Code 0 at %q1g5G[RBgR%&*YOO.U4:121262164
001012:000000:0020 FAILURE: Code 66406 at %q1g5G[RBgR%&*YOO.U4:213129639
005003:000000:0000 Failed to save title 3 to file C:/Users/Andie/Desktop/title03.mkv
005004:000000:0000 0 titles saved, 2 failed
005037:000000:0204 Copy complete. 0 titles saved, 2 failed.
Application exited at Wed Dec 02 22:32:41 2009
microjazz
#56 Post by microjazz » Thu Dec 03, 2009 6:40 pm
The Star Trek blu ray seasons didn't work in 1.4.8 but in 1.4.9 they are working with a few exceptions. On some of the blu rays episodes are missing in the makemkv selection. For example on disks 2-4 in the first season, 1 episode is missing from each mkv rip. I checked the blu ray on my ps3 and all the episodes are in the menu but makemkv does not see all of the episodes for some reason.
#57 Post by mike admin » Sun Dec 06, 2009 8:24 am
kevinbal wrote:The Duchess, US BD disc. Fatal Error causes program to quit part way through encode of main title.
Your log is packed with read errors. Seems like a bad disc or drive.
1105 L-EC UNCORRECTABLE ERROR
1502 POSITIONING ERROR DETECTED BY READ OF MEDIUM
#58 Post by mike admin » Sun Dec 06, 2009 8:25 am
kevinbal wrote:Coraline, US BD
same thing, this time a single error all time. your drive seems to be a no good.
#59 Post by mike admin » Sun Dec 06, 2009 8:29 am
Well, it is what it says - it looks like these 2 discs are not region1 discs and you have a drive that _really_ enforces the region code. my only advice is to try to read them with another drive.
#60 Post by mike admin » Sun Dec 06, 2009 8:31 am
microjazz wrote:The Star Trek blu ray seasons didn't work in 1.4.8 but in 1.4.9 they are working with a few exceptions. On some of the blu rays episodes are missing in the makemkv selection. For example on disks 2-4 in the first season, 1 episode is missing from each mkv rip. I checked the blu ray on my ps3 and all the episodes are in the menu but makemkv does not see all of the episodes for some reason.
please provide the full log from 1.4.9. Thanks!
