Boxcab
Re: SDFtool Flasher
Post by Boxcab » Wed Apr 08, 2026 11:57 am
I'm going to try to update the firmware on my ASUS BW-16D1X-U (a USB connected drive). Any suggestions, warnings or tricks that I need to be aware of??
Thanks in advance.
Re: SDFtool Flasher
Post by Billycar11 » Wed Apr 08, 2026 1:19 pm
Boxcab wrote: Wed Apr 08, 2026 11:57 am I'm going to try to update the firmware on my ASUS BW-16D1X-U (a USB connected drive). Any suggestions, warnings or tricks that I need to be aware of??
Thanks in advance.
if its mt1959
see op or guide below or email me or marty for the auto flasher
if its an a pioneer platform email me the drive info
see below for email
Boxcab
Re: SDFtool Flasher
Post by Boxcab » Wed Apr 08, 2026 3:20 pm
Here's the info on the drive from MakeMKV...
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: KLOK36I***
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
I do not see the "mt1959" reference anywhere here or on the drive.
Sorry for my knowledge void!
Boxcab
Re: SDFtool Flasher
Post by Boxcab » Wed Apr 08, 2026 3:22 pm
Son of a b...
Yes I see it does say MT1959.
Sorry.
oldshield1
Re: SDFtool Flasher
Post by oldshield1 » Tue Apr 21, 2026 5:59 pm
Well, Bit confused.
I have the firmware pack my drive though internal to my pc is, I think, listed under slim external drives.
OS device name: E:
Current profile: DVD-ROM
Product: BD-RE BU40N
Revision: U104
Serial number: xxxxxxxxx
Firmware date: 2121-11-17 09:58
Highest AACS version: 82
I have written current firmare to my pc so i have a backup.
From you list of firmwares
do i use
DE_LG_BU40N_1.00.bin
or
DE_LG_BU40N_1.03_MK.bin
or something completely different?
thanks in advance.
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Apr 21, 2026 10:03 pm
oldshield1 wrote: Tue Apr 21, 2026 5:59 pm Well, Bit confused.
OS device name: E:
Revision: U104
do i use
or
thanks in advance.
FYI, since your BU40N has encrypted firmware that backup only contains the important Cal data and is not the whole firmware file.
Also, since the firmware is encrypted, you must flash BU40N 1.03-MK first. You can leave it on that firmware if you only use MakeMKV or Xreveal for UHD ripping otherwise, if you use other UHD ripping software such as DVDFab then you should flash BU40N 1.00 next.
oldshield1
Re: SDFtool Flasher
Post by oldshield1 » Wed Apr 22, 2026 3:59 am
thank you so much.
command produced error code 0xff056103 when using the DE_LG_BU40N_1.03_MK.bin file
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Apr 22, 2026 4:12 am
oldshield1 wrote: Wed Apr 22, 2026 3:59 am thank you so much.
Take the disc out of the drive and close the tray.
oldshield1
Re: SDFtool Flasher
Post by oldshield1 » Wed Apr 22, 2026 4:18 am
Goodness, I feel Dumb. yes, that worked.
MrMegadeth99
Re: SDFtool Flasher
Post by MrMegadeth99 » Wed Apr 22, 2026 2:13 pm
So I followed the steps to flash my BP50NB40 drive. Make MKV says Liberdrive is enabled but the drive still won't read 4K discs. Any idea what's wrong?
Re: SDFtool Flasher
Post by d00zah » Wed Apr 22, 2026 2:19 pm
MrMegadeth99 wrote: Wed Apr 22, 2026 2:13 pm So I followed the steps to flash my BP50NB40 drive. Make MKV says Liberdrive is enabled but the drive still won't read 4K discs. Any idea what's wrong?
Looks like you've only done the 1st part. See the "to flash the BP50NB40 SVC:NB52" notes in the 1st post of this topic.
MrMegadeth99
Re: SDFtool Flasher
Post by MrMegadeth99 » Wed Apr 22, 2026 2:42 pm
Ok I definitely did both parts now it looks like this but same issue, not reading 4K discs. Can anyone please assist?
Re: SDFtool Flasher
Post by Billycar11 » Wed Apr 22, 2026 2:43 pm
whats the svc code on the drive if its not nb50 or 52 you bricked it
MrMegadeth99
Re: SDFtool Flasher
Post by MrMegadeth99 » Wed Apr 22, 2026 3:00 pm
Its NB52. Its not bricked it can still read blu rays.
Re: SDFtool Flasher
Post by Billycar11 » Wed Apr 22, 2026 3:49 pm
MrMegadeth99 wrote: Wed Apr 22, 2026 3:00 pm Its NB52. Its not bricked it can still read blu rays.
That image differs from the other one you posted it showed as bp60 there
Now it's back to bp50
Go back to bp60 fw
