Help with Buffalo drive
alexscotti
Post by alexscotti » Thu Apr 02, 2026 5:28 pm
I bought this drive. It showed up in makemkv as :
OS device name: H:
Product: BD-RE BH16NS58
Revision: 1.03
Serial number:
Firmware date: 2120-05-08 09:33
Bus encryption flags: 1F
Highest AACS version: 82
i flashed it to 1.02 following the instruction on this site. it shows up now as:
Os device name: H:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLQOA8D3243
Drive platform: MT 1959
Firmware version: 1.02
BD raw metadata read: Yes Unrestricted read speed: Yes
looking good. but thats as far as it gets. it cant actually read any blu ray or uhd blu ray disc. when i put one in i get:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243' at offset'1179648' Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16N60 1.02 KLQOA8D3243 at offset 1179648' udt: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH 16NS60 1.02 KLQOA8D3243' at offset 2359296' Error Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243' at offset 2422784 uat: node felefe failed!
Error 'Scsi error - ILLEGAL REQUEST: INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16N60 1.02 KLQOAD3243 at offset 720896'
uat: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243 at offset 7208L,]"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243' at offset 2097152
A udf: node fe/efe failed!
Error Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading BD-RE HL-DT-ST BD-RE WH 16NS60 1.02 KLQOA8D3243' at offset 2097152'
DVD.
Error Scsi error. - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while readina BD-RE HL-DT-ST BD-RE WH16N60 1.02 KLOOA8D3243 at offset 1703936'
and makemkv says "no disc inserted."
I'm not sure what to do here. Any help please. Thanks!
Re: Help with Buffalo drive
Post by Billycar11 » Fri Apr 03, 2026 3:23 am
clean the discs
Post by MartyMcNuts » Fri Apr 03, 2026 4:37 am
alexscotti wrote: Thu Apr 02, 2026 5:28 pm I bought this drive. It showed up in makemkv as :
OS device name: H:
Revision: 1.03
Serial number:
Os device name: H:
Revision: 1.02
DVD.
Yep, as Billy said, clean the discs. Even if they look pristine, give'em a clean! UHD discs often have an invisible layer of film on them from the manufacturing process that needs to be wiped off.
Also, let Windows initialise the disc and you can see it in explorer before you open the MakeMKV application.
alexscotti
Post by alexscotti » Mon Apr 20, 2026 3:48 pm
I started working with same disc no cleaning. I really have no idea. I think I power cycled. Not sure wat was going on but it works. Thanks!
