CPD-002 could not be read by MakeMKV
comadose
#1 Post by comadose » Thu Apr 09, 2026 3:16 pm
Disc CPD-002 (Japanese pro-wrestling) could not be read by MakeMKV.
It keeps retrying but never manages to read the disc, and is unable to rip it. DVD Decryptor worked okay.
Once ripped, MakeMKV was able to open the ISO and extract the video. I tried two different Pioneer ODDs.
Re: CPD-002 could not be read by MakeMKV
#2 Post by Billycar11 » Sun Apr 12, 2026 7:56 am
did you try different opening modes?
comadose
#3 Post by comadose » Sun Apr 12, 2026 8:18 am
It's impossible to select a mode, because it get stuck in a loop trying to recognize the disc.
#4 Post by dcoke22 » Sun Apr 12, 2026 7:32 pm
It is often recommended to let the OS see the disc before opening MakeMKV.
comadose
#5 Post by comadose » Mon Apr 13, 2026 7:31 am
Thanks dcoke22, that didn't work either though.
comadose
#6 Post by comadose » Sun Apr 19, 2026 9:14 am
Is there any way to get the developer to take a look at this disc? I can send it to them.
Ezatoka
#7 Post by Ezatoka » Sun Apr 19, 2026 5:46 pm
comadose wrote: Sun Apr 12, 2026 8:18 am It's impossible to select a mode, because it get stuck in a loop trying to recognize the disc.
then start MakeMKV without the disc being in the drive and set the opening mode beforehand.
comadose
#8 Post by comadose » Mon Apr 20, 2026 9:30 am
If I open MakeMKV and then connect the drive, I am able to open the .IFO file manually and rip the streams. However, I'm trying to make a backup of the disc (ISO), and I can't do that in manual mode. Thanks.
#9 Post by Coopervid » Mon Apr 20, 2026 12:51 pm
comadose wrote: Mon Apr 20, 2026 9:30 am If I open MakeMKV and then connect the drive, I am able to open the .IFO file manually and rip the streams. However, I'm trying to make a backup of the disc (ISO), and I can't do that in manual mode. Thanks.
Rip it and use Imgburn to create the ISO.
comadose
#10 Post by comadose » Mon Apr 20, 2026 2:35 pm
I have an ISO made with DVD Decryptor. I'm trying to get a bug reported.
