With what error?bkwashby wrote: Sun Apr 19, 2026 4:38 pmYes, when I try to load the disc it fails.MartyMcNuts wrote: Sun Apr 19, 2026 7:45 amThis shouldn't need flashing. Have you tried a UHD disc yet?bkwashby wrote: Sat Apr 18, 2026 10:44 pm Hello
I'm looking to flash my drive so I can rip UHD discs, can anyone help?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.02
Serial number: CBDL008388UC
Firmware date: 2022-10-24
Bus encryption flags: 13
Drive platform: RS8E21
Firmware version: 1.02/ID05
BDR-XS07S UHD Flash
Re: BDR-XS07S UHD Flash
bkwashby
This is what it says:MartyMcNuts wrote: Sun Apr 19, 2026 9:27 pmWith what error?bkwashby wrote: Sun Apr 19, 2026 4:38 pmYes, when I try to load the disc it fails.MartyMcNuts wrote: Sun Apr 19, 2026 7:45 am
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.1 id=CA5C627C459A)
Downloading latest HK to C:\Users\Bryan/.MakeMKV ...
Saved AACS dump file as C:\Users\Bryan/.MakeMKV/MKB20_v61_Ready_Player_One_6B49.tgz
So there are no actual read errors. Your issue is clear.bkwashby wrote: Mon Apr 20, 2026 9:49 pmThis is what it says:
You need to fix your HK download issue otherwise you won't be able to rip a lot of UHD discs. MakeMKV needs to be able to download it's HK database to get the UHD decryption keys. Your computer is most likely geo-blocking Russia (that's where the HK is downloaded from). You should fix this geo-blocking or you could try running MakeMKV through a VPN.
bkwashby
I got it working. I do use a VPN, turns out my VPN was blocking.MartyMcNuts wrote: Tue Apr 21, 2026 12:13 amSo there are no actual read errors. Your issue is clear.bkwashby wrote: Mon Apr 20, 2026 9:49 pmThis is what it says:
Thanks for your help
zittrig
I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Produkt: BD-RW BDR-XS07
Revision: 1.01
Serienummer: XXXXX
Firmware-Datum: 2020-09-03
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 82
Drive platform: RS8E20
Firmware version: 1.01
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
PM sent.zittrig wrote: Tue May 05, 2026 6:52 pm I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
zittrig
Works perfectly, thank you very much!
sure email me that info and all others email me no need to post your info here just reach out to me directlyzittrig wrote: Tue May 05, 2026 6:52 pm I was able to buy a BDR-XS07TS surprisingly cheap. For 4K Support I would be very grateful:
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.01
Serienummer: XXXXX
see below for email
PudgeGrandDaddy
So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
Serial number: SKDL000809UC
Firmware date: 2020-09-03
Highest AACS version: 68
Revision: 1.01
PM sent.PudgeGrandDaddy wrote: Wed May 27, 2026 6:22 pm So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
sure email me that info and all others email me no need to post your info here just reach out to me directlyPudgeGrandDaddy wrote: Wed May 27, 2026 6:22 pm So I have I think the same (or similar) drive as zittrig. This is a new account for me as my old one I guess I can't get in (my old email is inaccessible. I'd love to be able to play UHD on it but cannot ATM.
Revision: 1.01
see below for email
barish
deleted by request
sure email me that info andbarish wrote: Tue Jun 02, 2026 5:30 pm
Revision: 1.00
Serial number: TFDL001558UC
Firmware date: 2019-01-07
Highest AACS version: 81
Firmware version: 1.00
all others email me no need to post your info publicly here just reach out to me directly
see below for email
PM sent.barish wrote: Tue Jun 02, 2026 5:30 pmHey cooper, would you mind helping me too? I just registered so i can't PM you directly, but it would be greatly appreciated.
Revision: 1.00
rickygrove
I've got 1.01 firmware on this drive and would like to patch. Thanks in advance.
