Top Gun Blu Ray Disc
Back_up_AZ
Post by Back_up_AZ » Sun Apr 19, 2026 9:01 pm
this is wild when i put this disc in and i start the process about two minutes in is starts puking debug codes, so i hit stop, it do not stop. ever. so when i kill it through windows it leaves the file. owned by Make mkv and you cannot delete this file until you reboot. i did it three times. lol. going to try with the 4k disc next but anybody thinks this is weird? if anybody has a solution , would love to hear it. 4k disc take up way to my space and most 1080 looks awesome Ai upscaled
Back_up_AZ
Re: Top Gun Blu Ray Disc
Post by Back_up_AZ » Sun Apr 19, 2026 9:55 pm
same thing happens with the 4k version wow MakeMkV Crashes on Coping either disc blu ray or 4K disc wtf anybody else able to copy this?
Back_up_AZ
Post by Back_up_AZ » Sun Apr 19, 2026 10:07 pm
it crashes aka wonders off into the great unknown thinking it is still coping spitting out debug codes then it just stops putting out codes so no dump, no information other than first screen
OS device name: E:
Product: BD-RE WH16NS60
Revision: 1.03
Serial number: KX1OANI0908
Firmware date: 2120-05-08 10:10
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: Top_Gun
Timestamp: 2020-04-17 08:51:00
Protection: AACS v68
Data capacity: 44.50 Gb
Disc type: BD-ROM
Number of layers: 2
next...
MakeMKV v1.18.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\joel/MakeMKV_log_1.txt
Using LibreDrive mode (v06.3 id=4083C4CCDB14)
File 00001.mpls was added as title #0
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00196.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00197.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00010.mpls is equal to title 00001.mpls and was skipped
File 00176.mpls was added as title #1
Title #00206.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00700.mpls(1) has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00198.mpls was added as title #2
Title #00013.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00254.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00588.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00179.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00181.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00183.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00184.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00185.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00014.m2ts was added as title #3
File 00015.m2ts was added as title #4
Title #00024.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00251.m2ts was added as title #5
File 00252.m2ts was added as title #6
File 00263.m2ts was added as title #7
File 00272.m2ts was added as title #8
File 00273.m2ts was added as title #9
File 00274.m2ts was added as title #10
File 00275.m2ts was added as title #11
File 00276.m2ts was added as title #12
Title #00262.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00266.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00267.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00268.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00269.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00270.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00271.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00253.m2ts was added as title #13
File 00589.m2ts was added as title #14
File 00255.m2ts was added as title #15
File 00256.m2ts was added as title #16
File 00257.m2ts was added as title #17
File 00258.m2ts was added as title #18
File 00259.m2ts was added as title #19
File 00260.m2ts was added as title #20
File 00261.m2ts was added as title #21
File 00264.m2ts was added as title #22
File 00590.m2ts was added as title #23
File 00591.m2ts was added as title #24
File 00592.m2ts was added as title #25
File 00593.m2ts was added as title #26
File 00594.m2ts was added as title #27
File 00595.m2ts was added as title #28
choose this file
Name: Top Gun (English)
Source file name: 00001.mpls
Duration: 1:49:26
Chapters count: 16
Segment count: 1
Segment map: 351
File name: Top Gun_t00.mkv
and my MakeMKV crashes a couple minutes into coping . ANY HELP???
Post by MartyMcNuts » Mon Apr 20, 2026 5:26 am
Back_up_AZ wrote: Sun Apr 19, 2026 10:07 pm it crashes aka wonders off into the great unknown thinking it is still coping spitting out debug codes then it just stops putting out codes so no dump, no information other than first screen
OS device name: E:
Revision: 1.03
Disc Information
Label: Top_Gun
Disc type: BD-ROM
Number of layers: 2
next...
choose this file
Duration: 1:49:26
Chapters count: 16
Segment count: 1
Segment map: 351
So what are the errors in the log when it crashes? All you've shown is the log before starting a rip.
You could try doing a full disc backup first (click the folder icon in the menu, 2nd from left) then generating the mkv from the disc folder backup.
Also, you are using the shit firmware. WH16NS60 1.02-MK is the recommended version and works best.
Back_up_AZ
Post by Back_up_AZ » Thu Apr 30, 2026 8:49 pm
there are zero errors?? it just stops reading disc and keeps writing but noting happens . anyway so i got another drive and flashed it 1.05 and the same thing happens . so I went to the library and got a blu ray disc from them and the same thing happens. i am completely unable to copy any top gun blu ray disc. the latest attempt it crashes at the end point and a dialog box comes up Failed this is new. the discs i have are pristine so not any issue with reading poor quality disc. I am going to continue on until i a, able to make a MKV of Top Gun on blu ray???
Back_up_AZ
Post by Back_up_AZ » Thu Apr 30, 2026 10:00 pm
got it new drive
