Backing up HD-DVD discs in 2026?
maples
Post by maples »
I recently started backing up my media library, and I have some HD-DVD discs which I would like to back up (Specifically, Star Trek: The Original Series, all 3 seasons, on the HD-DVD and standard-DVD combo pack with one format on each side of the physical disc).
However, I've had a quite difficult time getting MakeMKV to work with these discs.
The drive is a LG GGW-H20L, and it seems to be in good working condition. I've used it to successfully back up several DVD and Blu-Ray discs without issue.
Operating system is Ubuntu 24.04 LTS, with MakeMKV installed via https://launchpad.net/~heyarje/+archive ... kemkv-beta
When I insert a disc then open MakeMKV, it seems to hang indefinitely on the "detecting CD-ROM drives" step.
When I open MakeMKV, select the drive, then insert a disc, I get the spinning disk icon indefinitely. (When this happens, the /usr/bin/makemkvcon guiserver A0001+shm process goes to 100% of a single CPU.)
Once, I was able to get MakeMKV to the "Decrypting" step, but I have not been able to replicate that.
I have heard that sometimes there is an issue with the physical disc degrading. So I tried taking a disc image with `ddrescue`. It completed with no errors (and at a decent speed too, about a half hour for a 21GB image). So I don't think it's an issue with the physical disc.
I tried opening the ISO file itself in MakeMKV, but that didn't work either. It opened the ISO okay, then spent some time on the "Decrypting" step, then outputted this error log:
MakeMKV v1.18.3 linux(x64-release) started
Debug logging enabled, log will be saved as /home/anthony/MakeMKV_log.txt
Evaluation version, 26 day(s) out of 30 remaining
DEBUG: Code 0 at S{\1-j6N>Jamw4_#:121267063
Title #CBS.EVO has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #Intro.EVO has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #black.EVO has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #Legal_ES.EVO has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #Disclaimer_ES.EVO has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The source file '/HVDVD_TS/menu.EVO' is corrupt or invalid at offset 727040, attempting to work around
The source file '/HVDVD_TS/menu.EVO' is corrupt or invalid at offset 755712, attempting to work around
The source file '/HVDVD_TS/menu.EVO' is corrupt or invalid at offset 786432, attempting to work around
The source file '/HVDVD_TS/menu.EVO' is corrupt or invalid at offset 817152, attempting to work around
DEBUG: Code 0 at rS'kX[?E+(}mX}1,lG$:213132376
DEBUG: Code 0 at rS'kX[?E+(}mX}1,lG$:213131272
DEBUG: Code 0 at Hf16[[(@X"xi$qX<cOP*:213131157
DEBUG: Code 0 at Hf16[[(@X"xi$qX<cOP*:121262647
DEBUG: Code 425 at Hf16[[(@X"xi$qX<cOP*:121261773
DEBUG: Code 0 at 6ys2-Sj@+U2`ewnXI>8;;:213129984
DEBUG: Code 0 at 6ke}K!XcO4K"uoO)%e8A3:121268972
DEBUG: Code 1 at ZLYTr,ep,n=\)Iug:121262578
DEBUG: Code 0 at g/{GRX8Y<-5!C~6:213138494
The source file '/HVDVD_TS/Eps07.EVO' is corrupt or invalid at offset 8192, attempting to work around
The source file '/HVDVD_TS/Eps07.EVO' is corrupt or invalid at offset 18432, attempting to work around
The source file '/HVDVD_TS/Eps07.EVO' is corrupt or invalid at offset 32768, attempting to work around
DEBUG: Code 19 at Hf16[[(@X"xi$qX<cOP*:121261773
DEBUG: Code 2 at ZLYTr,ep,n=\)Iug:121262578
The source file '/HVDVD_TS/Eps05.EVO' is corrupt or invalid at offset 6144, attempting to work around
The source file '/HVDVD_TS/Eps05.EVO' is corrupt or invalid at offset 10240, attempting to work around
The source file '/HVDVD_TS/Eps05.EVO' is corrupt or invalid at offset 14336, attempting to work around
DEBUG: Code 9 at Hf16[[(@X"xi$qX<cOP*:121261773
DEBUG: Code 4 at Hf16[[(@X"xi$qX<cOP*:121261773
The source file '/HVDVD_TS/Eps04.EVO' is corrupt or invalid at offset 6144, attempting to work around
I've attached a copy of MakeMKV_log.txt from reading the ISO; I skimmed it but nothing stuck out to me as abnormal besides the errors outputted above.
For kicks and giggles, I spun up a Windows VM and installed MakeMKV there to try to read the ISO, but got the same results.
Any ideas on what I should try next?
MakeMKV_log.txt
(16.64 KiB) Downloaded 953 times
wiliamcorlin
Re: Backing up HD-DVD discs in 2026?
Post by wiliamcorlin »
Hey, interesting setup — don’t see HD-DVD questions much anymore :)
From what you described, it actually doesn’t sound like a drive issue. The fact that ddrescue pulled a clean 21GB image at normal speed is a pretty good sign your LG GGW-H20L is reading the disc fine at the hardware level.
The errors you’re getting in MakeMKV (all those .EVO “corrupt or invalid” messages) point more toward MakeMKV struggling with the HD-DVD structure itself, not necessarily physical damage. HD-DVD support in MakeMKV has always been a bit spotty compared to DVD/BD, and it hasn’t really been a focus for years.
Also the “detecting CD-ROM drives” hang + makemkvcon pegging CPU is something I’ve seen mentioned before with older formats — kind of like it gets stuck parsing the disc layout.
One thing I’d try is instead of going through MakeMKV first, open the ISO with something like VLC or another tool that supports HD-DVD structure and see if the .EVO files actually play нормально. If they do, that confirms the data is fine and it’s just a MakeMKV limitation.
Another angle — those combo discs can be weird. Since they’re HD-DVD on one side and DVD on the other, sometimes detection gets confused depending on how the drive reports it.
When you mount the ISO, do you see a clean /HVDVD_TS structure with proper .EVO files, and can any of them be played directly outside of MakeMKV? That might help narrow down whether it’s parsing vs actual data issues.
m20120
Post by m20120 »
I was going to ask if your drive (GGW-H20L) supports reading HD-DVD, but a quick google search seems to indicated that it should.
I have a bunch of HD-DVD titles (including the Star Trek set you mentioned). I backed them up years ago and also was able to rip another HD-DVD title in the past few months. I am using an external Microsoft XBox HD-DVD player that I bought a long time ago. Running MakeMKV on Windows with no issues. I am not sure if you have enough HD-DVD titles that makes it worth finding a different drive or not. The XBox 360 HD-DVD drives do seem to be around and might do the trick.
tomty89
Post by tomty89 »
You might want to try an older version (something as old as 1.17.6). There have been reports that newer versions have problem getting a non-LibreDrive to work for the case of (regular) Blu-ray, so perhaps the issue affect the case of HD DVD as well.
I have basically zero idea about how things work in HD DVD, but AFAIK for Blu-ray MakeMKV can't really do anything with just an encrypted ISO (or the content of it), as it needs to retrieve some information from some non-regular/LBA area on the disc (aka BD-ROM mark?). An ISO, at least one you make with a "general" utitlity like ddrescue, wouldn't consists of that.
Frank886t
Post by Frank886t »
It’s fascinating to see someone still working on preserving HD-DVD collections in 2026, especially with rare releases like the Star Trek: The Original Series box set. The amount of troubleshooting with MakeMKV, different environments, and disk imaging shows great effort and attention to detail. Hopefully the community can help identify whether the issue comes from HD-DVD compatibility, EVO file handling, or some hidden protection layer, and find a reliable method to archive these valuable discs before they become even harder to access.
