Flashing LibreDrives
deamon_k
Post by deamon_k »
I have two Blueray Drives,
A very old Hp DVDWBD TS-LB23L drive and a new HL-DT-ST BD-RE BU50N drive. I had inconsistent results on the HL-DT-ST Product: BD-RE BU50N until I loaded the libredrive firmware, but now that drive rips great. I'm trying to locate the correct firmware for the Hp DVDWBD TS-LB23L drive, that one is still giving me trouble and I want to see if I can get that one working by loading the libredrive firmware. I know it won't read UHD disks, but I can still use it to rip regular bluray disks.
MakeMKV drive information below:
OS device name: \Device\CdRom4
Revision: GE03
Serial number: **********
Firmware date: 2118-01-22 14:36
Bus encryption flags: 1F
Highest AACS version: 65
OS device name: \Device\CdRom3
Manufacturer: hp
Product: DVDWBD TS-LB23L
Revision: 0400
Drive platform: MT1939
Thanks,
Re: Flashing LibreDrives
deamon_k wrote: Fri Apr 17, 2026 1:24 am I have two Blueray Drives,
Revision: GE03
Manufacturer: hp
Revision: 0400
Thanks,
Nope, don't believe there's anything for that old HP. It should rip blu-ray discs fine. If you are having issues, it has nothing to do with LibreDrive and is more likely to be the lasers. Have you tried cleaning them?
tomty89
Post by tomty89 »
Not really sure if it's related but my brand new ASUS BC-12D2HT wasn't able to rip a regular blu-ray on Linux (MakeMKV 1.18.3) until I flashed it with MK firmware. (I don't remember what was the exact response but I think MakeMKV just sort of hang/loop indefinitely when attempt to "parse" the disc and get ready. I think the disc eventually stopped spinning after a while.) I have only tested with one disc released in 2019 though and it's the first and only disc inserted into the drive ever so far.
I thought it was "expected" but was it not?
tomty89 wrote: Fri Apr 17, 2026 2:51 am Not really sure if it's related but my brand new ASUS BC-12D2HT wasn't able to rip a regular blu-ray on Linux (MakeMKV 1.18.3) until I flashed it with MK firmware. (I don't remember what was the exact response but I think MakeMKV just sort of hang/loop indefinitely when attempt to "parse" the disc and get ready. I think the disc eventually stopped spinning after a while.) I have only tested with one disc released in 2019 though and it's the first and only disc inserted into the drive ever so far.
You know you should let the OS initialise the disc and see it in explorer or whatever Linux has before opening up MakeMKV.
tomty89
Post by tomty89 »
The OS had no problem initialize it. It was just MakeMKV. IIRC I tried both having MakeMKV started first or otherwise. I actually tried many times before flashing the drive (because for reasons I wanted to make a rip of that particular BD before MK-ising the drive but eventually I gave up because of this) so I'm pretty sure the MK firmware did cause the difference. I'm just not sure what's the exact "reason" behind the scene. (FWIW the original firmware was one version newer than the MK one IIRC. The drive was probably from like a last batch of the model.)
(Also as per my mileage with my old Pioneer BDR-S08XLT, starting MakeMKV after "the OS has initialized the disc" often results in a hang, while I don't remember that has ever happened if I start MakeMKV before inserting a disc.)
deamon_k
Post by deamon_k »
Yep, tomty89, this is similar to my experince. I'm trying to set up a dedicated ripping box on linux using the Linux Automated Ripper Machine scripts, and while the drives are all detected in linux as /dev/sd* something, but neither the HP nor the HL-DT-ST would consistently detect/read disks. Both drives behaved better in windows on the same machine. Once I flashed the HL-DT-ST with libre drive firmware I had no problems reading or ripping drives in linux. The dediciated ripping system is working pretty well.
Unfortunately, the HP drive still is acting erratically.
MartyMcNuts , I haven't tried cleaning the drive laser. Does rubbing alchohol and qTips work? Or is there better advice out there?
Thanks for the help.
deamon_k wrote: Sat Apr 18, 2026 12:11 am
Yep, rubbing alcohol and qtip, then dry straight away with another qtip or 2 to ensure it is all clean and dry.
deamon_k
Post by deamon_k »
Appreciate the suggestion MartyMcNuts,
Cleaning with a qtip and alcohol has been a big improvement. In windows I can now watch several Bluray disks via VLC and I'm tetsing extracting tracks with MakeMKV. However, in the dedicated Linux box it just stalls
04-18-2026 23:37:53 ARM: INFO: ************* Ripping disc with MakeMKV *************
04-18-2026 23:37:53 ARM: INFO: Updating MakeMKV key...
04-18-2026 23:37:53 ARM: INFO: Starting MakeMKV rip. Method is mkv
I left it overnight, but it sits for hours maxing one CPU with no actual progress. MakeMKV in windows has the main title taking about an hour.
The BD-RE BU50N still works in linux with the same disks. I'm not sure what the problem is.
deamon_k wrote: Sun Apr 19, 2026 6:44 pm Appreciate the suggestion MartyMcNuts,
What firmware version did you put on the BU50N?
tomty89
Post by tomty89 »
If you really need to get the HP drive working in Linux, I suggest that you give 1.17.7 and/or 1.17.6 a go.
deamon_k
Post by deamon_k »
MartyMcNuts wrote: Sun Apr 19, 2026 9:38 pm
I'm running a rip now, I'll double check when thats completed. I'm pretty sure it was "HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin" from the MK Firmware pack with the SDFtool flasher.
deamon_k
Post by deamon_k »
tomty89 wrote: Mon Apr 20, 2026 11:56 pm
tomty89 , is that in the "mk-firmware-pack-20200720" pack? I'm not seeing anything that matches. Is there another file I should be looking for?
deamon_k wrote: Tue Apr 21, 2026 12:13 am
He's talking about MakeMKV v1.17.7 (or v1.17.6). There is no firmware for that HP drive.
deamon_k
Post by deamon_k »
Ah, I see. Thanks MartyMcnuts
