Post
by SamuriHL » Wed Apr 15, 2026 2:05 am
jayper wrote: Wed Apr 15, 2026 1:27 am
Would love some assistance, I am still running the last CPM build from last year.
Can I upgrade from CPM to the avdvplus builds? Or do I need to start fresh?
You can upgrade. Just make sure to read the release 1 release notes about it. You have to reset the Dolby Vision section in the CoreELEC settings. DO NOT MAKE THE MISTAKE OF RESETTING THE WHOLE INSTALL! Just that one page there's a reset settings. No need to wipe anything. And that'll work just fine on R9.
Specifically this and pay CLOSE attention to what he's saying or you WILL wipe the box if you're not careful.
After you install my build please make sure to go to Settings/System/CoreELEC on the bottom of the screen and press "Reset above settings to default" and confirm with "yes" so my screen changes are aligned correctly. This is the screen settings "reset" NOT the CoreELEC "soft reset" and definitely NOT the "hard reset". After resetting the screen settings you can then select the appropriate settings for your equipment.
jayper
Post
by jayper » Thu Apr 16, 2026 2:58 pm
SamuriHL wrote: Wed Apr 15, 2026 2:05 am
Appreciate the guidance on this. Very helpful! I am up and running.
Now I just need to figure out WTF is going on with my LG C3. Anytime I play back one of my remuxes, especially those with cm40 metadata added, I get a near constant Dolby Vision notification when an Atmos stream is playing.
I've tested numerous HDMI certified cables. Played content right of an SSD usb drive. Hardwired ethernet.
I'm losing it. I'm starting to wonder if I have bum HDMI port in my Ugoos or something.
Post
by SamuriHL » Thu Apr 16, 2026 3:20 pm
Set the audio to LAV SB in the settings.
jayper
Post
by jayper » Thu Apr 16, 2026 3:49 pm
SamuriHL wrote: Thu Apr 16, 2026 3:20 pm
Thanks. Pretty sure that was the setting I had configured, but I will double-check.
Post
by SamuriHL » Thu Apr 16, 2026 4:11 pm
jayper wrote: Thu Apr 16, 2026 3:49 pm
It definitely happens in LAV FULL but LAV SB shouldn't trigger it unless something's changed. I have zero control over it. CPM also looked into it and neither of us could fix it. I don't send audio to the display at all so I never see it.
jayper
Post
by jayper » Thu Apr 16, 2026 4:59 pm
SamuriHL wrote: Thu Apr 16, 2026 4:11 pm
Yeah, I had this issue as well with the A14 CPM builds as well.
Everything else about my setup is perfect, so I need to look into ways to strip Atmos and/or not set it to the TV.
Post
by SamuriHL » Thu Apr 16, 2026 9:58 pm
jayper wrote: Thu Apr 16, 2026 4:59 pm
I use my VRROOM for that.
dapope
Post
by dapope » Sun Apr 19, 2026 1:26 pm
RESET_9999 wrote: Sun Oct 13, 2024 12:54 pm
thats apple stupid static color reshaping. All their DV contents have this difference: red always looks brighter/orangish. sometimes it's less apparent.
this static metadata is removed when you convert the rpu to P8. Apple has no respect to the creator's intent, I did a video about it on my youtube channel.
Never watch iTunes P5 web-dl if you care about accuracy, always convert it to P8.
Hi, how can I convert P5 to P8?
Trees
Post
by Trees » Thu Jun 25, 2026 1:04 pm
Does Apple still do this? I've watched quite a lot of Apple content, but I haven't noticed anything out of the ordinary. That said, I've never compared it to the source material, either.
ragico
Post
by ragico » Sun Jul 12, 2026 10:41 pm
Hey, long time this forum did not work. Now is back.
deadchip12
Post
by deadchip12 » Mon Jul 13, 2026 1:48 am
Anything new with the ugoos am6b+? Haven't revisited this forum for a long time.
yossSP
Post
by yossSP » Sun Aug 02, 2026 11:49 pm
Hello @RESET_9999, do you think the DV FEL playback quality of the Ugoos AM9 Pro is as good as the AM6B+?
Recently, AM9 Pro has get experimental DV FEL support on CoreElec 22 and this device has AV1/H266 playback support, so it will be more future proof than AM6B+.
MagnusWelch
Post
by MagnusWelch » Thu Aug 06, 2026 8:31 am
Tested this out on my LG OLED and it works like a charm. The resulting file triggers DV playback without any issues
