Gatorman
Post by Gatorman »
Alldu
Post by Alldu »
Gatorman wrote:
Wed Apr 01, 2026 4:55 pm
Hmm. Maybe ask here. https://www.avsforum.com/threads/ugoos- ... 6/page-608
Thanks for the tip, will do!
jayper
Post by jayper »
SamuriHL wrote:
Sat Dec 27, 2025 11:26 pm
https://github.com/avdvplus/Builds/releases
That's the latest but make sure you go back and read the release notes for R1 and R2, as well. avdvplus did a LOT of work on Dolby Vision.
EDIT: Fixed the link...accidentally posted the same R3 link again.
Would love some assistance, I am still running the last CPM build from last year.
Can I upgrade from CPM to the avdvplus builds? Or do I need to start fresh?
Post by SamuriHL »
jayper wrote:
Wed Apr 15, 2026 1:27 am
You can upgrade. Just make sure to read the release 1 release notes about it. You have to reset the Dolby Vision section in the CoreELEC settings. DO NOT MAKE THE MISTAKE OF RESETTING THE WHOLE INSTALL! Just that one page there's a reset settings. No need to wipe anything. And that'll work just fine on R9.
Specifically this and pay CLOSE attention to what he's saying or you WILL wipe the box if you're not careful.
After you install my build please make sure to go to Settings/System/CoreELEC on the bottom of the screen and press "Reset above settings to default" and confirm with "yes" so my screen changes are aligned correctly. This is the screen settings "reset" NOT the CoreELEC "soft reset" and definitely NOT the "hard reset". After resetting the screen settings you can then select the appropriate settings for your equipment.
jayper
Post by jayper »
SamuriHL wrote:
Wed Apr 15, 2026 2:05 am
Appreciate the guidance on this. Very helpful! I am up and running.
Now I just need to figure out WTF is going on with my LG C3. Anytime I play back one of my remuxes, especially those with cm40 metadata added, I get a near constant Dolby Vision notification when an Atmos stream is playing.
I've tested numerous HDMI certified cables. Played content right of an SSD usb drive. Hardwired ethernet.
I'm losing it. I'm starting to wonder if I have bum HDMI port in my Ugoos or something.
Post by SamuriHL »
Set the audio to LAV SB in the settings.
jayper
Post by jayper »
SamuriHL wrote:
Thu Apr 16, 2026 3:20 pm
Thanks. Pretty sure that was the setting I had configured, but I will double-check.
Post by SamuriHL »
jayper wrote:
Thu Apr 16, 2026 3:49 pm
It definitely happens in LAV FULL but LAV SB shouldn't trigger it unless something's changed. I have zero control over it. CPM also looked into it and neither of us could fix it. I don't send audio to the display at all so I never see it. :)
jayper
Post by jayper »
SamuriHL wrote:
Thu Apr 16, 2026 4:11 pm
Yeah, I had this issue as well with the A14 CPM builds as well.
Everything else about my setup is perfect, so I need to look into ways to strip Atmos and/or not set it to the TV.
Post by SamuriHL »
jayper wrote:
Thu Apr 16, 2026 4:59 pm
I use my VRROOM for that.
dapope
Post by dapope »
RESET_9999 wrote:
Sun Oct 13, 2024 12:54 pm
thats apple stupid static color reshaping. All their DV contents have this difference: red always looks brighter/orangish. sometimes it's less apparent.
this static metadata is removed when you convert the rpu to P8. Apple has no respect to the creator's intent, I did a video about it on my youtube channel.
Never watch iTunes P5 web-dl if you care about accuracy, always convert it to P8.
Hi, how can I convert P5 to P8?
