I have three dvds that I can't convert using this software.
Here is the log file for the first title:
Debug log started at Wed Dec 02 06:17:14 2009 , written by MakeMKV v1.4.9 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.9 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Gil/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003028:000000:0000 Cell 22 was discarded (structure protection?)
003036:000000:0000 Title #0 was added (21 cell(s), 1:39:36)
003020:000000:0000 Title #1 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #2 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #3 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #5 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #6 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #7 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:000000:0000 Cell 2 was discarded (structure protection?)
003036:000000:0000 Title #8 was added (1 cell(s), 0:02:45)
003020:000000:0000 Title #9 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #10 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003036:000000:0000 Title #11 was added (1 cell(s), 0:15:40)
003020:000000:0000 Title #12 has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #13 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory E:/dvd
001012:000000:0020 FAILURE: Code 2042 at )(M&=6iv+w[us~sD)]":121262785
001012:000000:0020 FAILURE: Code 0 at jO;U-c4et;`hTV*`TTo":121262164
001012:000000:0020 FAILURE: Code 58606 at jO;U-c4et;`hTV*`TTo":213129639
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file E:/dvd/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Any ideas?
Gil
Failed to save title with version 1.4.9
Re: Failed to save title with version 1.4.9
From error log it looks like an incorrect VOB file. Is it a commercial DVD or you created it with some program?
gilsh
I'm not sure
I bought it in China. It looks like a commercial dvd but you can never be sure.
The dvd is playable on dvd player / computer.
No problem ripping it with DVD Decrypter / DVD Shrink.
There is no problem re-encoding it with DVD Shirnk.
The problem is that I want to get rid of the VOB container and use MKV instead.
Thanks for your quick response...
Any ideas how I can overcome this problem.
Thanks,
Gil
Thanks,
Gil
