I format my laptop a lot and most my licensed programs offer the ability to de-activate the license.
I also own 2 laptops but never use them at the same time so my questions are:
1) Am I able to uninstall/reinstall MakeMKV and register the program with my licenses freely or is there a limit?
2) Is it ok to use it on 2 laptops provided they're not being used actively at the same time? My 2nd laptop is just a backup laptop.
Licensing question / reinstallation
superspartan
ASUS ROG Strix SCAR 16 G635LX | Core Ultra 9 275HX | 64GB RAM | GeForce RTX 5090 | 16" QHD+ 240Hz Mini LED Display | 2x 8TB SSDs
ASUS Zephyrus G14 GA403UH | AMD Ryzen 9 270 | 16GB RAM | GeForce RTX 5050 | 14" 3K 120Hz OLED Display | 4TB SSD
Re: Licensing question / reinstallation
Keep your key where you can copy/paste it in. The same key will work for multiple machines. Personally, I keep mine in the email that I received, up until someone stole multiple computers last year. Then I needed to find one of my remaining computers to pull it from.
I used to also run it on 2 or 3 machines at the same time, when doing large reads. 3 machines gave me 5 drives normally, plus drives that could be plugged in via USB.
superspartan
Got it, thank you.Woodstock wrote: Tue Apr 14, 2026 8:54 pm Keep your key where you can copy/paste it in. The same key will work for multiple machines. Personally, I keep mine in the email that I received, up until someone stole multiple computers last year. Then I needed to find one of my remaining computers to pull it from.
