Verbatim 43888 on linux not ripping
librelibre
Post by librelibre »
I'm having trouble with this drive. Most Blurays are failing to both back up or make mkvs. Some of them can play. I cleaned the discs multiple times and they look fine, no damage.
I decided to try ddrescue to see if anything else was going on, noticed If it pauses for a couple seconds it disconnects and I have to eject the disc and put it back in. Sometimes unplug and replug. Not sure if that's the issue with makemkv also.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: xxxxxxxxxxxx
Highest AACS version: 81
Firmware version: 1.03
Re: Verbatim 43888 on linux not ripping
librelibre wrote: Tue Apr 14, 2026 5:08 am I'm having trouble with this drive. Most Blurays are failing to both back up or make mkvs. Some of them can play. I cleaned the discs multiple times and they look fine, no damage.
Revision: 1.03
Most likely a power issue since these drives are very power hungry. Use an USB-C port at the rear of a desktop or a powered USB hub.
librelibre
Seems a poorly planned drive, no external power, no y cable. Also finicky when it comes to cables. The cable it comes with is usb c to a, with an adapter to work with usb c. The adapter helped, but didn't solve the issue. Tried a certified usb c to c cable. Had to plug unplug and reboot a few times before it was able to read the drive. Didn't fix the issue.
Looked into a powered hub already for something else, it seems like they're not reliable and can cause damage. And a bit of a lottery, no real predictability with brand or price.
I'm seeing if I can order a drive with an external power brick. Hopefully that will be better. And hopefully it gets to me in good condition and not beat to hell.
librelibre wrote: Tue Apr 14, 2026 2:21 pm Seems a poorly planned drive, no external power, no y cable. Also finicky when it comes to cables. The cable it comes with is usb c to a, with an adapter to work with usb c. The adapter helped, but didn't solve the issue. Tried a certified usb c to c cable. Had to plug unplug and reboot a few times before it was able to read the drive. Didn't fix the issue.
In addition BU40N 1.0 is recommended for Linux insted of 1.03.
