Flashing Verbatim 43888 from Linux
simland
Post by simland » Wed Mar 18, 2026 6:57 pm
Hi, just got the 43888 and have not been able to flash from Linux (I don't have anything with Windows). When I use makemkvcon from the shell there is simply no response at all to the flash command. Other commands do work.
I am using PopOS which is Ubuntu based. I usually used the MakeMKV flatpak which works just fine. I have also downloaded the src/bin and built/installed with no problems. I got the 'The all you need firmware pack.zip'.
When I plug it in:
[101498.475361] usb 2-1: new SuperSpeed USB device number 6 using xhci_hcd
[101498.491095] usb 2-1: New USB device found, idVendor=18a5, idProduct=0428, bcdDevice= 1.cd
[101498.491114] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[101498.491123] usb 2-1: Product: Verbatim 4K BD RW
[101498.491130] usb 2-1: Manufacturer: Verbatim
[101498.491137] usb 2-1: SerialNumber: 0025084C09D5
[101498.493448] usb-storage 2-1:1.0: USB Mass Storage device detected
[101498.494750] scsi host4: usb-storage 2-1:1.0
[101499.556499] scsi 4:0:0:0: CD-ROM            HL-DT-ST BD-RE BU40N      1.05 PQ: 0 ANSI: 0
[101499.559299] sr 4:0:0:0: Power-on or device reset occurred
[101499.564676] sr 4:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[101499.572408] sr 4:0:0:0: Attached scsi CD-ROM sr0
[101499.572618] sr 4:0:0:0: Attached scsi generic sg1 type 5
$ makemkvcon f -l
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
  HL-DT-ST_BD-RE_BU40N_1.05_212404231347_MO1P7JI5138
   makemkvcon f -d /dev/sr0 --info
SDF.bin version: 0x00A5
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N     1.05:N000300:-
As far as I can tell I should be flashing like this:
makemkvcon f --all-yes -d /dev/sr0 rawflash enc -i ./HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Am I doing something wrong?
Thanks for any advice.
Re: Flashing Verbatim 43888 from Linux
Post by MartyMcNuts » Wed Mar 18, 2026 10:52 pm
simland wrote: Wed Mar 18, 2026 6:57 pm Hi, just got the 43888 and have not been able to flash from Linux (I don't have anything with Windows). When I use makemkvcon from the shell there is simply no response at all to the flash command. Other commands do work.
When I plug it in:
$ makemkvcon f -l
Found 1 drives(s)
8013:Status
8001:Drive platform
:MT1959
For Linux flashing, use an older version. Nothing newer than v1.17.7
Post by Billycar11 » Wed Mar 18, 2026 11:23 pm
Also make sure to go down to 1.00 after mk
simland
Post by simland » Fri Mar 20, 2026 5:34 pm
Thanks,
I found the old versions here (in case anyone else is looking): makemkv.com/download/old
I successfully flashed with:
makemkvcon f -d'dev_21:1' -f ./sdf.bin rawflash slim,enc -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Post by MartyMcNuts » Fri Mar 20, 2026 10:17 pm
simland wrote: Fri Mar 20, 2026 5:34 pm Thanks,
Now flash down to BU40N 1.00 for use on Linux.
librelibre
Post by librelibre » Fri Apr 10, 2026 11:42 am
I hadn't seen this before. What is the benefit of flashing 43888 down to BU40N 1.00 for linux?
Post by Billycar11 » Fri Apr 10, 2026 6:11 pm
librelibre wrote: Fri Apr 10, 2026 11:42 am I hadn't seen this before. What is the benefit of flashing 43888 down to BU40N 1.00 for linux?
It makes it work
librelibre
Post by librelibre » Tue Apr 14, 2026 5:55 am
> librelibre wrote: ↑
> It makes it work
I read the guide and it said to flash to BU40N 1.03MK. I did not see where it said to flash down to flashing 43888 down to BU40N 1.00 for linux. The instructions for a different drive gives you a choice of firmware, so I guess sometimes it's a matter of preference. So is this a preference, a new bug, or necessary? Because it's not in the guide, and if it's necessary the guide should be updated. No need to be snippy. Just trying to understand what is going on.
Post by MartyMcNuts » Tue Apr 14, 2026 6:39 am
librelibre wrote: Tue Apr 14, 2026 5:55 am Re: Flashing Verbatim 43888 from Linux
> librelibre wrote: ↑
> It makes it work
There's a bug in Linux version so use BU40N 1.00.
