PIONEER BDR-209 change the Firmware ?
Lucian_1984
Re: PIONEER BDR-209 change the Firmware ?
Post by Lucian_1984 » Sun Feb 22, 2026 12:15 pm
Is there nothing that can be done for these drives with the 2023 firmware?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.55
Serial number:
Firmware date: 2023-02-16
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 1.55/ID60
Fizbin
Post by Fizbin » Sun Mar 08, 2026 4:36 am
EDIT... I ended up contacting Billy. Thanks.
OS device name: E:
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Highest AACS version: 81
Firmware version: 1.33
libreloon
Post by libreloon » Sun Apr 12, 2026 2:00 am
I am also hoping to get patched for UHD. I appreciate the help. Thank you!
Current profile: DVD-ROM
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: ---
Firmware date: 2018-05-08
Firmware version: 1.51/ID61
Post by Coopervid » Mon Apr 13, 2026 11:31 am
libreloon wrote: Sun Apr 12, 2026 2:00 am Hello,
Revision: 1.51
Serial number: ---
PM sent.
Post by Billycar11 » Mon Apr 13, 2026 11:49 am
Revision: 1.51
Serial number: ---
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
icedDisk
Post by icedDisk » Thu May 07, 2026 9:25 pm
Hi, new user and I just bought MakeMKV
The drive cannot read 4k disks.
Here are the drive infos:
OS device name: F:
Revision: 1.51
Serial number: xxxxx
Drive platform: RS8601
I would really appreciate help in how to change firmware to support 4k in MKV.
Post by Billycar11 » Thu May 07, 2026 10:38 pm
icedDisk wrote: Thu May 07, 2026 9:25 pm Hi, new user and I just bought MakeMKV
OS device name: F:
Revision: 1.51
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
rigoalfo
Post by rigoalfo » Thu May 21, 2026 8:48 am
Hello, sorry for my bad english. I can not english. This write with help from google dolmetsching. I have found this site with google search. I search firmware for my PIONEER BD-Writer and found this forum. Can you help my with firmware for my hardware please? I see for other user posting this info:
Laufwerksinformation
OS-Gerätename: /dev/sr0
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 1.52
Serienummer: QDDL050871WL
Firmware-Datum: 2019-01-11
Markierungen der Bus-Verschlüsselung: 13
Firmware version: 1.52/ID60
I thank you for you help.
Post by Billycar11 » Thu May 21, 2026 2:32 pm
rigoalfo wrote: Thu May 21, 2026 8:48 am Hello, sorry for my bad english. I can not english. This write with help from google dolmetsching. I have found this site with google search. I search firmware for my PIONEER BD-Writer and found this forum. Can you help my with firmware for my hardware please? I see for other user posting this info:
Produzent: PIONEER
Revision: 1.52
see below for email
Post by Coopervid » Thu May 21, 2026 9:07 pm
Produzent: PIONEER
Revision: 1.52
PM sent.
rigoalfo
Post by rigoalfo » Fri May 22, 2026 1:16 am
Very thanks "Billycar11" and "Coopervid" for your fast answer. Your PM is for BDR-212, my hardware is a BDR-209M. Can i patch this firmware to my drive? Thanks for you answer.
zittrig
Post by zittrig » Tue May 26, 2026 6:24 am
Only question, no need of flashing tool right now, 'cause the drives are not mine (yet).
BDR-209BK (yes, not a MBK/DBK, only BK, prod. 2018) and BDR-209XJB (Prod. 2016)
Are the models known? Drive infos are not available.
Post by Billycar11 » Tue May 26, 2026 7:54 am
zittrig wrote: Tue May 26, 2026 6:24 am Only question, no need of flashing tool right now, 'cause the drives are not mine (yet).
both should be flashable to do UHD
zittrig
Post by zittrig » Tue May 26, 2026 10:15 am
Ok, thanks Billy! Perhaps I'll risk a closer look...
vitolwein
Post by vitolwein » Sun Jun 28, 2026 1:44 am
Hello! can you help me please?
OS device name: G:
Revision: 1.51
Serial number:
