Is there nothing that can be done for these drives with the 2023 firmware?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.55
Serial number:
Firmware date: 2023-02-16
Bus encryption flags: 13
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 1.55/ID60
PIONEER BDR-209 change the Firmware ?
Lucian_1984
Fizbin
Re: PIONEER BDR-209 change the Firmware ?
EDIT... I ended up contacting Billy. Thanks.
OS device name: E:
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Highest AACS version: 81
Firmware version: 1.33
OS device name: E:
Revision: 1.33
Serial number:
libreloon
I am also hoping to get patched for UHD. I appreciate the help. Thank you!
Current profile: DVD-ROM
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: ---
Firmware date: 2018-05-08
Firmware version: 1.51/ID61
Revision: 1.51
Serial number: ---
PM sent.libreloon wrote: Sun Apr 12, 2026 2:00 am Hello,
Revision: 1.51
Serial number: ---
sure email me that info and all others email me no need to post your info here just reach out to me directlylibreloon wrote: Sun Apr 12, 2026 2:00 am Hello,
Revision: 1.51
Serial number: ---
see below for email
icedDisk
Hi, new user and I just bought MakeMKV
The drive cannot read 4k disks.
Here are the drive infos:
I would really appreciate help in how to change firmware to support 4k in MKV.
OS device name: F:
Revision: 1.51
Serial number: xxxxx
Drive platform: RS8601
Unrestricted read speed: YesThanks
sure email me that info and all others email me no need to post your info here publicly just reach out to me directlyicedDisk wrote: Thu May 07, 2026 9:25 pm Hi, new user and I just bought MakeMKV
I would really appreciate help in how to change firmware to support 4k in MKV.Code: Select all
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-209D Revision: 1.51 Serial number: xxxxx Firmware date: 2018-05-08 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8601 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.51/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
see below for email
rigoalfo
Hello, sorry for my bad english. I can not english. This write with help from google dolmetsching. I have found this site with google search. I search firmware for my PIONEER BD-Writer and found this forum. Can you help my with firmware for my hardware please? I see for other user posting this info:
Laufwerksinformation
OS-Gerätename: /dev/sr0
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-209M
Revision: 1.52
Serienummer: QDDL050871WL
Firmware-Datum: 2019-01-11
Markierungen der Bus-Verschlüsselung: 13
Firmware version: 1.52/ID60
I thank you for you help.
Produzent: PIONEER
Revision: 1.52
sure email me that inforigoalfo wrote: Thu May 21, 2026 8:48 am Hello, sorry for my bad english. I can not english. This write with help from google dolmetsching. I have found this site with google search. I search firmware for my PIONEER BD-Writer and found this forum. Can you help my with firmware for my hardware please? I see for other user posting this info:
Produzent: PIONEER
Revision: 1.52
see below for email
PM sent.rigoalfo wrote: Thu May 21, 2026 8:48 am Hello, sorry for my bad english. I can not english. This write with help from google dolmetsching. I have found this site with google search. I search firmware for my PIONEER BD-Writer and found this forum. Can you help my with firmware for my hardware please? I see for other user posting this info:
Produzent: PIONEER
Revision: 1.52
rigoalfo
Very thanks "Billycar11" and "Coopervid" for your fast answer. Your PM is for BDR-212, my hardware is a BDR-209M. Can i patch this firmware to my drive? Thanks for you answer.
zittrig
Only question, no need of flashing tool right now, 'cause the drives are not mine (yet).
BDR-209BK (yes, not a MBK/DBK, only BK, prod. 2018) and BDR-209XJB (Prod. 2016)
Are the models known? Drive infos are not available.
both should be flashable to do UHDzittrig wrote: Tue May 26, 2026 6:24 am Only question, no need of flashing tool right now, 'cause the drives are not mine (yet).
zittrig
Ok, thanks Billy! Perhaps I'll risk a closer look...
vitolwein
Hello! can you help me please?
OS device name: G:
Revision: 1.51
Serial number:
OS device name: G:
Revision: 1.51
Serial number:
