Hi all,
Hoping someone can help me recover my drive. I've been trying to flash my ASUS BW-16D1HT (firmware 1.01) to 3.10MK on Linux (Pi OS aarch64) using makemkvcon 1.18.3.
I ran the following command which completed successfully (both "Sending flash image" and "Programming flash" hit 100%):
sudo makemkvcon f -d /dev/sr0 rawflash -i ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
After rebooting the drive now shows as HL-DT-ST BD-RE WH16NS40 BOOT — so it's stuck in bootloader mode because I didn't include the full flag.
I've tried everything I can think of to recover it:
rawflash full with both the ASUS 3.10MK and LG WH16NS40-NS50 1.05 bin files — "No drive tool logic found in SDF.bin"
Downloaded the standalone sdf.bin from makemkv.com/sdf.bin and used --sdf-file — same error
Tried --sdf-type flags and boot=MT1959 Boot JB8 — same error
Tried MakeMKV 1.17.6 OSS — still sdftool 2.6, same result
Tried on Windows 11 via USB passthrough with makemkvcon64.exe — same error
SDFtool Flasher GUI 1.3.6 — detects drive but says "does not have correct drive platform (MT1959)" and RECOVER is greyed out
The drive is connected via USB (Prolific bridge, external enclosure). I don't have bare metal SATA available.
Before the flash failed I did successfully dump the firmware:
dump_full_ASUS_BW-16D1HT_1.01_211302051930_K9KF23J3649.bin
Unfortunately this was in /tmp and got wiped on reboot before I could save it properly.
Drive details from sdftool:
makemkvcon f -l shows: HL-DT-ST_BD-RE__WH16NS40_BOOT
makemkvcon f -d /dev/sr0 help previously showed MTK19xx firmware module v1.30
Is there any way to recover this over USB without bare metal SATA/DOS? Any help massively appreciated.
BW-16D1HT stuck in BOOT mode after rawflash - sdftool "No drive tool logic found"
services@kadam.cloud
Re: BW-16D1HT stuck in BOOT mode after rawflash - sdftool "No drive tool logic found"
You should never have flashed it!!!! This is an older, pre 2016 model with the incompatible MT1939 drive platform.services@kadam.cloud wrote: Sat Apr 11, 2026 12:54 pm Hi all,
Nornally you would recover it on Windows using SDFtool flasher's RECOVER method. In the SDFtool Flasher thread, at the bottom of the first post are links to the tool and also the old ASUS BW-16D1HT 1.01 firmware.
But you may have fucked it completely with all the wrong shit you have tried.
You could try the old modified ASUS flasher as this flasher ignores most checks so it may/may not work but worth a try... The only other option left if that doesn't work is an old computer that has IDE mode so you can use Dosflash for recovery.
Thanks for your reply.
Sounds like I've royally fucked it up, yes. I bought this for £70 on Alixpress. Honestly, I haven't really got hours to pour over obscure methods. I've already spent hours messing around with this damn thing.
What would you suggest? I just want to buy a drive that's already flashed, or one that is easy to flash.
Found this
https://shop.uhdfriendlydrives.co.uk/closed
Is this best route? (Once it opens)
I live on a small irrelevant island called the UK
Here's Asmcom's thread on this forum: https://forum.makemkv.com/forum/viewtopic.php?f=20&t=19387
Check here:services@kadam.cloud wrote: Sun Apr 12, 2026 8:34 am Found this
viewtopic.php?f=20&t=41222
Hey Guys, I ended up buying LG BU40N 1.03MK drive. Is that fairly decent? Cant really afford to pay £300 - £500 for drives from the links shared here. Too expensive for me.
Let me know if that drive is up to scratch please. Thank you
The BU40N is the best LG drive and with the 1.03MK, in my opinion, it scratches at the quality of the the lower Pioneer drives like BDR-UD04 or BDR-XD05 series.
I had no clean disk which were ripped by a BDR-UD04 and which couldn't ripped by a BU40N 1.03MK. I had only one bad scratched disc in the past the BU40N couldn't rip but a BDR-UD04 had no problems. But that's only my personal expirience!
So, yes, the Pioneers are great, but the LG BU40N is not really bad and better than the internal LG drives.
thank you for sharing your exp, appreciated. Ripped first 10 BDs and going well so far with ARM on Ubuntu
