Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
Boxcab
Re: Asus BW-16D1X-U Platform RS8600 Firmware Flashing?
Post by Boxcab »
This looks like the place for help with my ASUS BR Drive... Can I get the tool to update my firmware?
Thank you in advance!!!
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number: KLOK36I***
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Highest AACS version: 76
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Boxcab wrote: Tue Apr 07, 2026 10:13 pm This looks like the place for help with my ASUS BR Drive... Can I get the tool to update my firmware?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
You have a LG type drive not a Pioneer. You can flash it with SDFTool. Recommended firmware is WH16NS60 1.02.
viewtopic.php?f=16&t=22896&hilit=SDFTool
Boxcab
Post by Boxcab »
I'll take a look. Thank you.
ketaminejedi
Post by ketaminejedi »
Any help flashing a platform RS8600 would be appreciated. I found the drive on eBay.
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Highest AACS version: 61
Drive platform: RS8600
Firmware version: 1.20/ID43
ketaminejedi wrote: Tue Apr 21, 2026 9:51 pm Any help flashing a platform RS8600 would be appreciated. I found the drive on eBay.
Revision: 1.20
Serial number:
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
TimC4711
Post by TimC4711 »
Hello, I have not been on this site for some time now and I tried a long time ago to see if this ASUS disc drive could burn 4K and at that time it was not on the list so, I was only burning BR to MKV. Has this changed? Here is the information less a few numbers on the serial number.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number: SFDL061.....
Firmware date: 2017-12-21
Highest AACS version: 68
Drive platform: RS8601
Firmware version: E111/ID76
Thanks,
Tim
TimC4711 wrote: Fri May 08, 2026 4:29 pm Hello, I have not been on this site for some time now and I tried a long time ago to see if this ASUS disc drive could burn 4K and at that time it was not on the list so, I was only burning BR to MKV. Has this changed? Here is the information less a few numbers on the serial number.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Thanks,
Tim
PM sent.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Thanks,
Tim
see below for email
bbod777
Post by bbod777 »
Hi, I'm new to the topic. Can anyone send me a firmware for this device to enable UHD support? Thank you for your help!
OS device name: G:
Product: BD-RW BDR-209M
Revision: 1.52
Serial number: ************
Firmware date: 2019-01-11
Bus encryption flags: 13
Highest AACS version: 64
Firmware version: 1.52/ID60
bbod777 wrote: Sat Jun 20, 2026 5:15 pm Hi, I'm new to the topic. Can anyone send me a firmware for this device to enable UHD support? Thank you for your help!
OS device name: G:
Revision: 1.52
see below for email
do we really need to do this? reply to every new person we were told years ago to stop this and take it off platform due to spam
but i feel as im forced to or someone else will
hbjsjny
Post by hbjsjny »
Hi Coopervid,
I have an ASUS BW-16D1H-U with the same RS8601 platform and E114/ID71 firmware. LibreDrive is already enabled, but the current firmware is still shown as “Original (unpatched),” and I would like to flash it with the appropriate firmware for UHD disc reading.
Could you please send me the correct firmware, flashing tool, and any necessary instructions?
Here is my MakeMKV drive information:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: [redacted]
Highest AACS version: 40
Firmware version: E114/ID71
Thank you very much for your help!
hbjsjny wrote: Sat Jul 25, 2026 12:48 pm
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
see below for email
M@tes
Post by M@tes »
Moin,
i need a little help ;-) i have this Drive and need firmware and infos for it:
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: A104
Serienummer: KLZL64F4043
Firmware-Datum: 2119-01-04 10:47
Markierungen der Bus-Verschlüsselung: 1F
I'm on Windows 11 for flashing. Thanks!
M@tes wrote: Sat Aug 01, 2026 10:29 am Moin,
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: A104
This is a LG drive. You can use SDFtool Flasher and flash it to WH16NS60 1.02-MK.
hbjsjny wrote: Sat Jul 25, 2026 12:48 pm Hi Coopervid,
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
PM sent.
