Pioneer Bluray Drive does not work in Linux Version
Jogibaer
Re: Pioneer Bluray Drive does not work in Linux Version
#16 Post by Jogibaer » Tue Apr 07, 2026 3:22 pm
OK, finally I flushed the Drives Firmware and all works perfectly now...
Thank you very much for all the information and tips
Linux Mint 22.2
Windows 11 (24H2)
MakeMKV 1.18.3 (compiled)
(Purchased Key)
BD-RW - Pioneer BDR-X13
BD-RW - Buffalo BRXL-16U3
16442496
#17 Post by 16442496 » Tue Apr 07, 2026 4:26 pm
Thank you very much for this information. This helped me to solve (workaround) the problem :-)
The firmware dump was missing from my Linux system, but was present on Windows. So I copied the dump file over and now everything works perfectly...
I'm glad that helped. :)
Firmware dump stop working since MakeMKV 1.17.8.
Without this workaround, i will stare "Endless spin" forever. ;)
(LibreDrive Information
Status: Possible, but very unlikely to happen)
#18 Post by Coopervid » Tue Apr 07, 2026 4:41 pm
16442496 wrote: Tue Apr 07, 2026 4:26 pm
Please post your Makemkv info.
16442496
#19 Post by 16442496 » Wed Apr 08, 2026 4:30 am
Old drive(s), but read bd/dvd discs very well.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-ROM BDC-202
Revision: 1.07
Serial number:
Firmware date: 2008-05-29
Drive platform: Pioneer RS1003
Firmware version: ID58
#20 Post by Coopervid » Wed Apr 08, 2026 9:12 am
16442496 wrote: Wed Apr 08, 2026 4:30 am
Revision: 1.07
Serial number:
This drive will not be supported.
