Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive
Trev UK
Post by Trev UK »
I bought the brilliant Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive in 2019, it still works perfectly.
I've only ever used it to rip DVDs and Blu-rays, can it rip 4K discs or do I need to change the firmware? unfortunately my PC only supports USB 2, I'll upgrade to a new PC soon.
https://www.amazon.co.uk/dp/B00BQTJ1DQ
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.50
Serial number:
Firmware date: 2017-12-21
Highest AACS version: 68
Drive platform: RS8601
Firmware version: 8.50/ID52
Re: Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive
Trev UK wrote: Sun Apr 05, 2026 10:59 pm I bought the brilliant Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive in 2019, it still works perfectly.
Revision: 8.50
Serial number:
It can read UHDs after flashing it. PM sent.
Revision: 8.50
Serial number:
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Trev UK
Post by Trev UK »
Thanks! I'll keep you updated.
Correction: My PC does have USB 3 :D
Trev UK
Post by Trev UK »
I followed the instructions, how does this look now? will it read/rip 4K discs...
Product: BD-RW BDR-S11
Revision: 1.53
Serial number:
Firmware date: 2020-08-03
Highest AACS version: 50
Drive platform: RS8801
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Trev UK wrote: Tue Apr 07, 2026 5:30 pm I followed the instructions, how does this look now? will it read/rip 4K discs...
Revision: 1.53
Serial number:
You're fine. Just get one and try it.
Trev UK
Post by Trev UK »
It works! Thanks for your help.
(I used a Bloodrayne 4K disc from Germany)
