BDR-XD07TS recently bought, looking for crossflash info!
zittrig
Re: BDR-XD07TS recently bought, looking for crossflash info!
Post by zittrig » Mon Feb 24, 2025 5:49 pm
Coopervid wrote: Mon Feb 24, 2025 5:24 pm
zittrig wrote: Mon Feb 24, 2025 4:22 pm I'll replace my 43890 by the following BDR-XD07TS. Any support for a 4k flash is welcome. Thank you in advance at this point.
Laufwerksinformation
OS-Gerätename: F:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07
Revision: 1.03
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-08-20
Markierungen der Bus-Verschlüsselung: 13
Highest AACS version: 77
Drive platform: RS8D30
Firmware version: 1.03
PM is coming.
Runs perfectly. Thanks a lot!
Seaglass
Post by Seaglass » Tue Feb 25, 2025 12:51 am
Hi - I have the same drive and I'm hoping I can also get info on how to flash it for HD?
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.00
Serial number: RCDL003406JP
Firmware date: 2017-10-30
Drive platform: RS8D31
Firmware version: 1.00/ID69
Post by dcoke22 » Tue Feb 25, 2025 1:20 am
Seaglass wrote: Tue Feb 25, 2025 12:51 am Hi - I have the same drive and I'm hoping I can also get info on how to flash it for HD?
Revision: 1.00
That drive will probably work as is for DVDs and regular HD blu-rays. You would only need to cross flash it if you're trying to rip 4K UHDs.
Post by Coopervid » Tue Feb 25, 2025 10:58 am
Revision: 1.00
PM sent.
Seaglass
Post by Seaglass » Tue Feb 25, 2025 1:00 pm
holy_sloth
Post by holy_sloth » Mon Sep 29, 2025 7:16 pm
OS-Gerätename: /dev/rdisk10
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Revision: 1.03
Serienummer:
Highest AACS version: 81
Post by Billycar11 » Tue Sep 30, 2025 6:07 am
holy_sloth wrote: Mon Sep 29, 2025 7:16 pm Laufwerksinformation
Produzent: PIONEER
Revision: 1.03
Serienummer:
sure just email me that info see below for email
Kazuyamk
Post by Kazuyamk » Wed Feb 11, 2026 9:19 pm
Hello
I also have this PIONEER-BDR-XD07TS drive manufactured in December 2020, but due to my stupidity, I installed firmware 1.06. :? I would like to install the software in UHD.
info: Drive Information
OS device name: J:
Revision: 1.06
Serial number:
Firmware date: 2024-10-09
Bus encryption flags: 13
Drive platform: Pioneer RS8D30
Firmware version: GENE
Post by MartyMcNuts » Thu Feb 12, 2026 6:34 am
Kazuyamk wrote: Wed Feb 11, 2026 9:19 pm Hello
OS device name: J:
Revision: 1.06
Serial number:
No. You ruined it for UHD, at least for now anyway. It's still good for standard blu-ray though. If you update your SDF.bin, you should be able to enable libredrive for blu-ray.
pmJcpPXK
Post by pmJcpPXK » Tue Apr 07, 2026 9:20 am
I have this drive also, any help would be appreciated.
OS device name: /dev/rdisk4
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Highest AACS version: 19
pmJcpPXK
Post by pmJcpPXK » Tue Apr 07, 2026 10:23 am
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.03
PM is coming.
I got the same drive info with only difference of Highest AACS version: 19. Can you give me some info regarding enabling the UHD? Thank you.
Post by Coopervid » Tue Apr 07, 2026 1:20 pm
pmJcpPXK wrote: Tue Apr 07, 2026 9:20 am I have this drive also, any help would be appreciated.
Revision: 1.03
Serial number:
PM is coming.
Post by Billycar11 » Tue Apr 07, 2026 1:28 pm
OS device name: J:
Revision: 1.06
Serial number:
pmJcpPXK wrote: Tue Apr 07, 2026 10:23 am
OS-Gerätename: F:
Produzent: PIONEER
Revision: 1.03
PM is coming.
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
