Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive
Trev UK
#1 Post by Trev UK » Sun Apr 05, 2026 10:59 pm
I bought the brilliant Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive in 2019, it still works perfectly.
I've only ever used it to rip DVDs and Blu-rays, can it rip 4K discs or do I need to change the firmware? unfortunately my PC only supports USB 2, I'll upgrade to a new PC soon.
https://www.amazon.co.uk/dp/B00BQTJ1DQ
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.50
Serial number:
Firmware date: 2017-12-21
Highest AACS version: 68
Drive platform: RS8601
Firmware version: 8.50/ID52
Re: Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive
#2 Post by Coopervid » Mon Apr 06, 2026 9:44 am
Trev UK wrote: Sun Apr 05, 2026 10:59 pm I bought the brilliant Buffalo BRXL-16U3-EU 16 x USB 3.0 External Blu-ray Drive in 2019, it still works perfectly.
Revision: 8.50
Serial number:
It can read UHDs after flashing it. PM sent.
#3 Post by Billycar11 » Mon Apr 06, 2026 9:56 am
Revision: 8.50
Serial number:
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Trev UK
#4 Post by Trev UK » Mon Apr 06, 2026 7:01 pm
Thanks! I'll keep you updated.
Correction: My PC does have USB 3 :D
Trev UK
#5 Post by Trev UK » Tue Apr 07, 2026 5:30 pm
I followed the instructions, how does this look now? will it read/rip 4K discs...
Product: BD-RW BDR-S11
Revision: 1.53
Serial number:
Firmware date: 2020-08-03
Highest AACS version: 50
Drive platform: RS8801
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
#6 Post by Coopervid » Tue Apr 07, 2026 6:11 pm
Trev UK wrote: Tue Apr 07, 2026 5:30 pm I followed the instructions, how does this look now? will it read/rip 4K discs...
Revision: 1.53
Serial number:
You're fine. Just get one and try it.
Trev UK
#7 Post by Trev UK » Sat Apr 11, 2026 6:23 pm
It works! Thanks for your help.
(I used a Bloodrayne 4K disc from Germany)
