PM sent.sugi1 wrote: Wed Sep 24, 2025 9:04 pm I seem to have the same problem. Any help is appreciated.
Drive info:Code: Select all
Loaded SDF.bin version 0x98 SDF.bin version: 0x0098 Drive Tool SDF present Drive Specific SDF present [Drive Specific SDF] Embedded Info Strings: 8000:LibreDrive Information 8013:Status 8105:Enabled 8001:Drive platform :RS8F00 8015:Firmware name :PIONEER BDR-212T 8002:Firmware type 8106:Original (unpatched) 8003:Firmware version :E116/ID71 8005:DVD all regions 8100:Yes 8006:BD raw data read 8100:Yes 8007:BD raw metadata read 8100:Yes 8009:Unrestricted read speed 8100:Yes [Drive Specific SDF] Embedded Status Message: 8099:Using LibreDrive mode (v%1 id=%2) :01.0 :D0CE65A7F569 Identification SDF present [Identification SDF] Embedded Info Strings: 8000:LibreDrive Information 8013:Status 8102:Possible, not yet enabled 8001:Drive platform :Pioneer RS8F00 8003:Firmware version :ID71 [Identification SDF] Drive autodetect string: pioneer:SAT :8F00:ID71: :ASUS :BW-16D1H-U E116: 20/07/21 :-
Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
Re: Get UHD Access From the E116 Version of ASUS BW-16D1H-U?
WALTunne
Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Informations lecteur
Nom du lecteur SE : F:
Fabricant : ASUS
Produit : BW-16D1H-U
Révision : E116
Numéro de série : DIDL120081WL
Date micrologiciel : 2020-07-21
Marqueurs d'encryptage bus : 1B
Drive platform: RS8F00
Firmware version: E116/ID71
Drive info :
Fabricant : ASUS
Révision : E116
PM is comimng. The forum is terribly slow and I have a lot of timeouts.WALTunne wrote: Wed Oct 01, 2025 9:06 pm Hello guys, i don't know which firmware i have to write. Can someone help me ?
Drive info :
Fabricant : ASUS
Révision : E116
ducky007
Hi folks, I been searching the forums and have not found a solution to get my drive to accept
UHD discs. Found this thread and I thought I try here. Help
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
Firmware date: 2020-07-21
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
x10bulls
Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent.ducky007 wrote: Tue Oct 07, 2025 5:07 pm Hi folks, I been searching the forums and have not found a solution to get my drive to accept
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: X
PM sent.x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
evo_day
@Coopervid, wonder if you could help me with the same?Coopervid wrote: Tue Oct 14, 2025 10:08 amPM sent.x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: *****************
Highest AACS version: 82
Sure. PM is coming.evo_day wrote: Mon Oct 27, 2025 11:19 am@Coopervid, wonder if you could help me with the same?Coopervid wrote: Tue Oct 14, 2025 10:08 amPM sent.x10bulls wrote: Mon Oct 13, 2025 10:19 pm Can I please get help for a working firmware to rip UHD titles. Here's my drive info:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
GDNCHN!
Could you send me that PM again? I haven't got time to see that. Thanks!Coopervid wrote: Thu Aug 28, 2025 8:51 pmPM sent.GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
The biggest difference between my drive and the common ones is that its firmware is "E116", compared to the often-seen ones with "E114" or "E115" firmware. But since the LibreDrive is enabled, I put an UHD disc inside. Surprisingly, after a while of reading, MakeMKV just simply told me that there is "No Disc" inside. That's awful. What should I do, or which firmware should I patch since its chip is not MT1959?
Sorry. Look elsewhere. Half a year after sending the firmware right away you lost youir window of opportunity. I just dislike slow people who ask for help and then disappear.GDNCHN! wrote: Fri Apr 03, 2026 5:57 amCould you send me that PM again? I haven't got time to see that. Thanks!Coopervid wrote: Thu Aug 28, 2025 8:51 pmPM sent.GDNCHN! wrote: Thu Aug 21, 2025 1:54 pm Drive Information
OS device name: H:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Sure email me that drive info section see below for emailCoopervid wrote: Fri Apr 03, 2026 7:09 pmSorry. Look elsewhere. Half a year after sending the firmware right away you lost youir window of opportunity. I just dislike slow people who ask for help and then disappear.
