We Are Marshall Fails to open
jmdager
Post by jmdager »
I have successfully ripped multiple dvds prior to attempting to rip We Are Marshall with MakeMKV.
It reads the disc okay and allows me to attempt to open it, but fails to open it due to many errors.
If anyone has an idea of what the issue may be, any help is greatly appreciated.
Disc Info:
Label: WE_ARE_MARSHALL
Timestamp: 2007-05-04 16:48:22
Protection: CSS/CPPM
Data capacity: 7.46 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Output Log:
DEBUG: Code 100864261 at mSHv1hk}.MpL;_ZYj<:213132445
DEBUG: Code 100864261 at mSHv1hk}.MpL;_ZYj<:121262302
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'DVD+R-DL ThinkPad Ultraslim DVD PL31 8SSDX0H33226L1CB6616399' at offset '0'
DEBUG: Code 2 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 2 at X_Q`2"KJuGp@<O:29393631
DEBUG: Code 0 at t9=xZ^1%BBy>K|^ Y:121263245
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
DEBUG: Code 3 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 3 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
DEBUG: Code 4 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 4 at X_Q`2"KJuGp@<O:29393631
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_05_1.VOB' at offset '0'
DEBUG: Code 5 at X_Q`2"KJuGp@<O:29400232
DEBUG: Code 5 at X_Q`2"KJuGp@<O:29393631
DEBUG: Code 118095996 at &zUO>=0yYM*;qG%t8r#+X\b:29394183
DEBUG: Code 0 at &zUO>=0yYM*;qG%t8r#+X\b:121263590
DEBUG: Code 0 at 7#MR{@HBo.ez7ec]o9Uy:29394689
DEBUG: Code 3221225649 at QpU860LV{}|}B]j|,_$%hs :29394919
DEBUG: Code 3221225649 at &zUO>=0yYM*;qG%t8r#+X\b:213130145
DEBUG: Code 3221225480 at QpU860LV{}|}B]j|,_$%hs :121262509
DEBUG: Code 3221225480 at &zUO>=0yYM*;qG%t8r#+X\b:29394183
DEBUG: Code 0 at g|Td]xYm%Lw_)*:29397104
DEBUG: Code 1939006 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2050065 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2099934 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2191618 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2278741 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2321996 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2372725 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2465529 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2567162 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2613615 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2730289 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2841061 at X_Q`2"KJuGp@<O:213132721
DEBUG: Code 2953512 at X_Q`2"KJuGp@<O:213132721
Title #1 declared length is 2:11:10 while its real length is 1:21:49 - assuming fake title
DEBUG: Code 65792 at g|Td]xYm%Lw_)*:29401497
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 131328 at g|Td]xYm%Lw_)*:29401497
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 196864 at g|Td]xYm%Lw_)*:29401497
Title #4 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 262400 at g|Td]xYm%Lw_)*:29401497
Title #5 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 in broken titleset was skipped
Title #7 in broken titleset was skipped
Title #8 in broken titleset was skipped
Title #9 in broken titleset was skipped
Re: We Are Marshall Fails to open
Errors like that indicate there's a spot on the disc that the optical drive can't read correctly. The standard advice is to gently clean the disc and try again.
