Good evening.
I took a gamble on a external UHD drive on Yahoo Japan. It's logitec branded. Internally it's an LG BP71N(see photo for details) I can't find any info on this forum about it I'm guessing it's not able to be flash modded. The price was good cost me 160AUD with shipping to the motherland so I'm not too upset.
Logitech number is LBD-PWA6U3CLW
Anyone got anything for me (Good or bad news)
LG BP71n
Re: LG BP71n
I'm guessing it's a BU40N rebrand.
But might as well be safe do a read of the firmware and send it in to Mike the developer he will let you know where to go from there.
B1gJ1mmy
Re: LG BP71n
Best way for me to reach Mike I'm very new to this forum? I did a firmware dump using sdftool would that be enough.
Thanks.
Thanks.
Re: LG BP71n
That will be enough to start but a full backup maybe needed
The developer will tell you the details the forum or email will work to get in touch but since your new you probably can't pm so just email and sent the dump file with it
B1gJ1mmy
Re: LG BP71n
Ok I sent a message using the contact us a couple of days ago. However I could not attach a file that way. I cant see a direct email or anything.
I'll attach it here just for the sake of it.
JesseWasRight
Re: LG BP71n
This post is pretty old but
FYI
I flashed BU40N on to the BP71N drive (on Linux)
And it now works flawlessly!
On Linux, Kubuntu 24.04, the latest `makemkvcon` 1.18.2 refused to work (hanging). I had to download the 1.17.7
https://www.makemkv.com/download/old/ma ... 7.7.tar.gz
and use the firmware HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin (from the `The all you need firmware pack` ZIP file)
My command was
The `sdf.bin` file is listed in Mike's posts.
FYI
My command was
makemkv-bin-1.17.7/bin/amd64/makemkvcon f -d /dev/sr0 -f /root/.MakeMKV/sdf.bin rawflash enc -i /root/mkmkv/HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin-
apteryx
Re: LG BP71n
Thank you for sharing this! You gave me the confidence to try on a recently purchased Logitech branded UHD Blu-ray drive (https://www.amazon.co.jp/-/en/dp/B08KPTZ79H):JesseWasRight wrote: Tue Jan 06, 2026 8:05 am This post is pretty old but
FYI
My command wasThe `sdf.bin` file is listed in Mike's posts.Code: Select all
$ makemkvcon f --list
Found 1 drives(s)
00: dev_21:1, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE_BU40N_1.03_211810241934_SIK05P7G84331With makemkv installed to my user profile with GNU Guix, I can now use environment variables defined in libbluray, which VLC relies on, to watch Blu-rays in VLC by setting e.g.:
export MAKEMKVCON=$(which makemkvcon)
export LIBAACS_PATH=$HOME/.guix-profile/lib/libmmbd
export LIBBDPLUS_PATH=$HOME/.guix-profile/lib/libmmbd
vlc /dev/sr0-
LifeAlgorithm
Re: LG BP71n
Thanks for sharing! I bought this one like two years ago through Suruga-Ya but I haven't tried flashing it until literally today. What a timing to find your answer haha.JesseWasRight wrote: Tue Jan 06, 2026 8:05 am This post is pretty old but
FYI
I flashed the mentioned firmware and I can confirm it works perfectly.
ppkhoa
Re: LG BP71n
Another BP71N that can be cross-flashed to BU40N: https://www.amazon.co.jp/-/en/Logitech- ... B0914VL632, received and flashed successfully on Jul 22nd, 2026
