I bought this drive. It showed up in makemkv as :
OS device name: H:
Product: BD-RE BH16NS58
Revision: 1.03
Serial number:
Firmware date: 2120-05-08 09:33
Bus encryption flags: 1F
Highest AACS version: 82
i flashed it to 1.02 following the instruction on this site. it shows up now as:
Os device name: H:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: KLQOA8D3243
Drive platform: MT 1959
Firmware version: 1.02
BD raw metadata read: Yes Unrestricted read speed: Yes
looking good. but thats as far as it gets. it cant actually read any blu ray or uhd blu ray disc. when i put one in i get:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243' at offset'1179648' Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16N60 1.02 KLQOA8D3243 at offset 1179648' udt: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH 16NS60 1.02 KLQOA8D3243' at offset 2359296' Error Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243' at offset 2422784 uat: node felefe failed!
Error 'Scsi error - ILLEGAL REQUEST: INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16N60 1.02 KLQOAD3243 at offset 720896'
uat: node fe/efe failed!
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243 at offset 7208L,]"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CD' occurred while reading BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLQOA8D3243' at offset 2097152
A udf: node fe/efe failed!
Error Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading BD-RE HL-DT-ST BD-RE WH 16NS60 1.02 KLQOA8D3243' at offset 2097152'
DVD.
Error Scsi error. - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while readina BD-RE HL-DT-ST BD-RE WH16N60 1.02 KLOOA8D3243 at offset 1703936'
and makemkv says "no disc inserted."
I'm not sure what to do here. Any help please. Thanks!
Help with Buffalo drive
Re: Help with Buffalo drive
clean the discs
Yep, as Billy said, clean the discs. Even if they look pristine, give'em a clean! UHD discs often have an invisible layer of film on them from the manufacturing process that needs to be wiped off.alexscotti wrote: Thu Apr 02, 2026 5:28 pm I bought this drive. It showed up in makemkv as :
OS device name: H:
Revision: 1.03
Serial number:
Os device name: H:
Revision: 1.02
DVD.
Also, let Windows initialise the disc and you can see it in explorer before you open the MakeMKV application.
alexscotti
I started working with same disc no cleaning. I really have no idea. I think I power cycled. Not sure wat was going on but it works. Thanks!
