I recommend 1.02 or 1.00Maskman wrote: ↑Mon Mar 30, 2026 10:18 pmThanks ! Which version please ? There is different versions of wh16ns60.
We don't know sometimes it's fine sometimes it's notViscous5182 wrote: ↑Mon Mar 30, 2026 6:38 pmHello, Im also considering to buy an Asus BW-16D1HT, specifically:
Model: BW-16D1HT
Complete model name: BW-16D1HT/BLK/B/AS
Manufacture date: July 2016
Model P/N: 90DD0200 - B30000
I would like to know if it's possible to make it able to rip UHD blu-rays while maintaining the ability to burn bluray discs, as I've read in the guide:
In some cases crossflashing an Asus drive to an LG or the other way around you may no longer be able to burn disks-SamuriHL
If that reveals possible what would be the best "firmware path" to follow?
If it's not then You just go to Asus fw and have to deal with the sleep bug
Thank you very muchBillycar11 wrote: ↑Mon Mar 30, 2026 10:49 pmI recommend 1.02 or 1.00
Well, after getting that specific Y cable, and confirming I can power the drive proper through it from an external dedicated power supply, still getting SCSI errors and won't run. I'm giving up on this drive. Probably just something about it isn't letting it work.farmboy wrote: ↑Fri Mar 27, 2026 10:49 pmcan you point to a specific "Y" cable?nicholfd wrote: ↑Thu Mar 19, 2026 3:41 am"HK Download" error - MakeMKV needs internet access to download keys. It is enabled by default. Check internet or confirm setting in MakeMKV allows Internet access. I *think* some downloads are from Russia(?) - make sure your FW/router is not blocking Regional IP addresses.
Download failure is not related to the SCSI error messages - those are still power related.
Desktop does not necessarily equal better power.
Use a "Y" cable w/2 x USB port connections, AC adapter (if chassis supports it), or a good, high amp output USB hub.
I've tried a few different types, but the ones I've gotten only allow power and data from the side with 1 connection (Side A) to either cable on the two cable side (Side B). Meaning that I cannot connect the the drive to side A, and have one cable on side B go to the computer and the other go to my 65W output USB-C. The power won't go from side B to side A. And it appears to be isolated so I can't send power across the two side B cables.
(hopefully this makes sense). I'm not finding a way to supply power AND data to the drive via two different sources.
Will buy a drive from one of you guys.
Thank you for the help, BTW! I do really appreciate it!!!
andidHayder
I tried looking through the forum but didn’t find an answer. I’m trying to flash using a Mac and it says to only use 1.17.7 for Linux but I was a bit confused on the wording of that was also true for Mac. 1.17.7 keeps getting a fatal error on MacOS Tahoe.
You can use current MakeMKV to flash on macOS. The commands to flash on macOS and Linux are similar, which is why they're often spoken about together.andidHayder wrote: ↑Thu Apr 02, 2026 3:48 amI tried looking through the forum but didn’t find an answer. I’m trying to flash using a Mac and it says to only use 1.17.7 for Linux but I was a bit confused on the wording of that was also true for Mac. 1.17.7 keeps getting a fatal error on MacOS Tahoe.
MacOS 15.4 introduced a change that broke MakeMKV. I think it was fixed in MakeMKV 1.18.0 or maybe 1.18.1 (I don't remember off the top of my head). MakeMKV 1.17.7 undoubtedly won't work on Tahoe.
“Fatal Error Occured” with MacOS 15.4 Developer Beta 1
andidHayder
Thanks!dcoke22 wrote: ↑Thu Apr 02, 2026 4:46 amYou can use current MakeMKV to flash on macOS. The commands to flash on macOS and Linux are similar, which is why they're often spoken about together.andidHayder wrote: ↑Thu Apr 02, 2026 3:48 amI tried looking through the forum but didn’t find an answer. I’m trying to flash using a Mac and it says to only use 1.17.7 for Linux but I was a bit confused on the wording of that was also true for Mac. 1.17.7 keeps getting a fatal error on MacOS Tahoe.
