Pioneer bdr 209 and Pioneer bdr 209m
fox8091
Re: Pioneer bdr 209 and Pioneer bdr 209m
Post by fox8091 »
Not able to initiate PMs yet, but I'd appreciate a flasher. Drive info below:
OS device name: H:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.10
Serial number: <snip>
Firmware date: 2013-09-10
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.10/ID61
fox8091 wrote: Fri Mar 27, 2026 6:24 pm Not able to initiate PMs yet, but I'd appreciate a flasher. Drive info below:
OS device name: H:
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
OS device name: H:
Revision: 1.10
PM sent.
chris-rg
Post by chris-rg »
Hi all,
also being intrested if I can upgarde my drive:
Product: BD-RW BDR-209M
Revision: 1.34
Serial number: PLDL043627WL
Firmware date: 2016-04-25
Firmware version: 1.34/ID60
Thanks a lot!
chris-rg wrote: Wed Apr 01, 2026 1:30 pm Hi all,
Revision: 1.34
Thanks a lot!
see below for email
Revision: 1.34
Thanks a lot!
Reload your browser.
Snitchy
Post by Snitchy »
Hi @Coopervid,
I hope you are doing well.
I recently got a Pioneer BDR-209M drive and would like to ask if this drive can be made UHD-friendly. If yes, could you please help me with the correct flashing approach?
MakeMKV reports the drive as:
Revision: 1.34
Highest AACS version: 82
I would rather ask before trying anything risky myself, since I do not want to flash an incompatible firmware.
I currently cannot send PMs yet, but I can provide the serial number or any additional information as soon as PMs are available for my account.
Thank you very much for your help.
Snitchy wrote: Sat May 30, 2026 11:25 am Hi @Coopervid,
Revision: 1.34
PM sent but thr forum is super slow. Not my fault.
no need to post your info here publicly just reach out to me directly
see below for email
Snitchy
Post by Snitchy »
Coopervid wrote: Sat May 30, 2026 8:05 pm
Revision: 1.34
Hi Coopervid,
thank you very much for your PM, the files and the tutorial.
Unfortunately I currently cannot reply to PMs, so I hope it is okay to answer here.
I followed your instructions and the BDR-209 flash worked perfectly. The drive is now detected as a BDR-S11 / BDR-211 and UHD discs work in MakeMKV. I also sent a donation via PayPal as a thank you.
I wanted to ask if you could also help me with another Pioneer drive, a slim BDR-UD03. I am trying to find out whether it can be crossflashed to enable UHD support as well.
MakeMKV reports it as:
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
If this drive can be made UHD capable, I would really appreciate your advice.
Thank you again for your help.
Will send another PM but the forum is horribly slow.
Snitchy
Post by Snitchy »
Coopervid wrote: Mon Jun 01, 2026 12:59 pm Will send another PM but the forum is horribly slow.
Hi Coopervid,
thank you very much for your help and for sending the files/tutorial.
Unfortunately I still cannot reply to PMs directly, so I am replying here.
The UD-03 flash worked perfectly!
Thanks again for sharing the files and the clear instructions. Much appreciated!
Snitchy wrote: Mon Jun 01, 2026 5:39 pm
Hi Coopervid,
You are very welcome!
BlamWungus
Post by BlamWungus »
Hi! I've been lurking for a while in the hopes I would eventually get a flashable drive. I snatched this one without really thinking. Hope it's flashable.
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Highest AACS version: 16
Firmware version: 1.20/ID61
BlamWungus wrote: Sat Jun 06, 2026 6:34 pm Hi! I've been lurking for a while in the hopes I would eventually get a flashable drive. I snatched this one without really thinking. Hope it's flashable.
Revision: 1.20
Serial number:
see below for email
