deadchip12
#11311 Post by deadchip12 » Wed Feb 18, 2026 11:54 pm
atomdelpro
#11312 Post by atomdelpro » Sat Mar 14, 2026 11:53 pm
Hi everyone, my father has a Sony x700U and I've tried to play some of the mp4 test files from the "Dolby_Vision_Stuff" google sheet. The one that works is "FEL TEST ST DL P7 CMV4.0 4000nits V4", and I can see the text. However, when I try to play some of the others, such as "Jurassic.Park.1993.BD NEW HDR12_ DV_Metadata_Levels_Comparison_CMv2.9_BL_FEL_Merged" I can't see any difference between the different screen shots. I tried the same file on my computer using Energy Media Player and I can clearly see the difference in the shots.
I'm playing the files off of USB stick, and I've tried to toggle Dolby Vision on and off via the menu of the X700U player.
This is the google sheet i've been referring to: https://docs.google.com/spreadsheets/d/ ... ue&sd=true
I grabbed the files from the "screenshot comp" sheet, specifically, the "DV Comp" links in the "DoVi" column. Should I be seeing a difference on my player via usb?
If this is the wrong thread, my apologies! Please point me to the right direction if you know where this might be better received. Thank you!.
#11313 Post by RESET_9999 » Sun Mar 15, 2026 2:28 pm
atomdelpro wrote: Sat Mar 14, 2026 11:53 pm Hi everyone, my father has a Sony x700U and I've tried to play some of the mp4 test files from the "Dolby_Vision_Stuff" google sheet. The one that works is "FEL TEST ST DL P7 CMV4.0 4000nits V4", and I can see the text. However, when I try to play some of the others, such as "Jurassic.Park.1993.BD NEW HDR12_ DV_Metadata_Levels_Comparison_CMv2.9_BL_FEL_Merged" I can't see any difference between the different screen shots. I tried the same file on my computer using Energy Media Player and I can clearly see the difference in the shots.
The X700, X800M2, and Oppo Dolby Vision playback is less dynamic than CMv4.0 players, but the Jurassic Park clip has a 4000-nit MDL, so it should still have an effect. Try remuxing the file to TS, maybe.
https://github.com/justdan96/tsMuxer/releases
atomdelpro
#11314 Post by atomdelpro » Sun Mar 15, 2026 3:26 pm
RESET_9999 wrote: Sun Mar 15, 2026 2:28 pm The X700, X800M2, and Oppo Dolby Vision playback is less dynamic than CMv4.0 players, but the Jurassic Park clip has a 4000-nit MDL, so it should still have an effect. Try remuxing the file to TS, maybe.
This worked! I was able to remux to a TS file and now I can see the difference. One thing for others who stumble upon this post, I was getting an error when trying to use the tsMuxerGUI from the GitHb page, I needed to also download tsMuxeR (nongui) and have both in the same folder in order for it to work.
joseluko
#11315 Post by joseluko » Fri Mar 20, 2026 7:50 am
Problem with Dolby Vision when creating Blu-ray structure with tsMuxeR
I have run into an issue while using tsMuxeR.
I have MKV files that I would like to convert into a Blu-ray disc structure (or ISO) so I can burn them to a physical disc.
The problem is that when the MKV file contains Dolby Vision, tsMuxeR gives a warning saying that the resulting disc may not play correctly.
I am not sure how to solve this issue. My goal is to keep some content that is only available on streaming platforms in a physical format.
Is there any way to fix this problem? Should I remove Dolby Vision, convert it, or use a different tool?
Any advice or guidance on where to look would be greatly appreciated.
Thank you very much.
#11316 Post by RESET_9999 » Sat Mar 21, 2026 3:30 pm
Yes, you need to remove DV if it’s a P8 hybrid WEB-DL. Only dual-layer, dual-track P7 is valid for Blu-ray discs with DV. A Blu-ray structure with P8 HEVC might still play on some Blu-ray players, but I’ve never tested it.
If the WEB-DL is cropped, the Blu-ray structure may not be valid either.
joseluko
#11317 Post by joseluko » Sun Mar 22, 2026 4:06 pm
RESET_9999 wrote: Sat Mar 21, 2026 3:30 pm Yes, you need to remove DV if it’s a P8 hybrid WEB-DL. Only dual-layer, dual-track P7 is valid for Blu-ray discs with DV. A Blu-ray structure with P8 HEVC might still play on some Blu-ray players, but I’ve never tested it.
How can I remove DV?
Mediainfo says this:
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 24.4 Mb/s
Width : 3 840 pixels
Height : 1 746 pixels
Frame rate : 24.000 FPS
Bit depth : 10 bits
Gatorman
#11318 Post by Gatorman » Fri Mar 27, 2026 12:58 am
Mode 2 of the script can do this. Start here https://forum.doom9.org/showthread.php?t=185317
LV8HD
#11319 Post by LV8HD » Tue Mar 31, 2026 12:56 pm
@RESET_9999 what do you think about https://github.com/tinof/hdr-analyze?
#11320 Post by RESET_9999 » Tue Mar 31, 2026 1:07 pm
LV8HD wrote: Tue Mar 31, 2026 12:56 pm @RESET_9999 what do you think about https://github.com/tinof/hdr-analyze?
useless since a free version of the official Dolby algo (cm_analyze) can be used to create proper cmv4.0 metadata.
LV8HD
#11321 Post by LV8HD » Tue Mar 31, 2026 1:10 pm
RESET_9999 wrote: Tue Mar 31, 2026 1:07 pm useless since a free version of the official Dolby algo (cm_analyze) can be used to create proper cmv4.0 metadata.
Yeah, but what about HDR analysis with MadVR integration?
#11322 Post by RESET_9999 » Tue Mar 31, 2026 1:33 pm
LV8HD wrote: Tue Mar 31, 2026 1:10 pm
nothing new here, been available in my scripts for years.
DoVi_Scripts\tools\madMeasurementAnalyzer.exe
LV8HD
#11323 Post by LV8HD » Tue Mar 31, 2026 6:53 pm
RESET_9999 wrote: Tue Mar 31, 2026 1:07 pm nothing new here, been available in my scripts for years.
Sure. I was just wondering how it differed from the current implementation in your script, since I haven't been able to find officially updated sources for madMeasurementAnalyzer.exe and madMeasureHDR.exe.
By the way, talking about the measurement process in general: the -qscale:v parameter in ProRes encoding specifies to the encoder to use variable bitrate, and the integer value specifies how aggressively to compress the final media.
How big of an impact does the -qscale:v parameter play in the measurement process (whether for HDR, Dolby Vision and HDR10+)? How much does it differ compared to a constrained variable bitrate encoding (as per ProRes specification)?
#11324 Post by RESET_9999 » Tue Mar 31, 2026 7:08 pm
LV8HD wrote: Tue Mar 31, 2026 6:53 pm Sure. I was just wondering how it differed from the current implementation in your script, since I haven't been able to find officially updated sources for madMeasurementAnalyzer.exe and madMeasureHDR.exe.
Well, the madvr data is the same regardless of the tool you use to read it.
Negligible difference, but I wouldn't use a value higher than 8...
Alldu
#11325 Post by Alldu » Wed Apr 01, 2026 1:05 pm
Hi guys,
I've used to play my muxed DV movies on Sony X700, and now switching to Ugoos am6b+ with coreELEC. Pretty happy with the new toy, but I have one small thing that bothers me. I'm a sucker for pgs subs which I make myself to represent their theatrical look as close as possible, when they are not burned in the transfer itself. I didn't have this problem with X700, but when playing plain white subs on Ugoos (movies, like Godfather or Salvador), it seems Ugoos adds a tiny grey outline to them - even though there shouldn't be any. Kinda small thing, but it is very visible on my 65'' Sony OLED A95K.
It looks like that with the new mkv files and my old m2ts files. I tried AI, and I understood the reason is that Ugoos reads those PGS somehow differently from X700 - thus, the outline. So is there a workaround for it, perhaps? Or it is what it is? Thanks!
