Pioneer BDR-XD05TS 4k compatibility?
Re: Pioneer BDR-XD05TS 4k compatibility?
Yes. Just not for you. But you can send all others my way.
comadose
Okay, well excuse me if I don't take your word for it.
Sure email me that drive info section see below for emaileroc1990 wrote: Mon Mar 30, 2026 6:30 pm Piling onto the pile with my own request. Also, is it possible to do so from Linux or will I need access to a Windows OS to do this? (I assume a VM will be sufficient, worst case).
Drive Information OS device name: /dev/sr0 Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.01 Serial number: <redacted> Firmware date: 2014-12-26 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8231 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.01/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
Makar
OS device name: /dev/rdisk4
Revision: 1.21
Firmware date: 2014-04-02
Highest AACS version: 77
Firmware version: 1.21
Revision: 1.21
PM sent.Makar wrote: Sat Apr 04, 2026 4:19 am Hi Cooper,
I was lucky enough to pick up a like new XD05 this week. Please advise.
I'm happy to donate.
Revision: 1.21
Makar
jjeoun
Hi Coopervid,
Looks like youve been able to help a lot of people. Hopefully, my drive is also flashable.
OS device name: G:
Revision: 3.01
Serial number: redacted
Highest AACS version: 82
OS device name: G:
Revision: 3.01
bdc01
I'm wondering if my XD05 can also be upgraded to support 4k reads.
OS device name: E:
Revision: 3.10
Firmware date: 2017-06-22
Drive platform: RS8232
Firmware version: 3.10/ID34
OS device name: E:
Revision: 3.10
Sure email me that drive info section see below for emailjjeoun wrote: Sun May 10, 2026 2:25 am Hi ,
OS device name: G:
Revision: 3.01
Sure email me that drive info section see below for emailbdc01 wrote: Fri Jul 31, 2026 9:08 pm Hi,
OS device name: E:
Revision: 3.10
PM sent.jjeoun wrote: Sun May 10, 2026 2:25 am Hi Coopervid,
OS device name: G:
Revision: 3.01
PM sent.bdc01 wrote: Fri Jul 31, 2026 9:08 pm Hi,
OS device name: E:
Revision: 3.10
NCiH85
Hi Coopervid,
Is my drive flashable?
OS device name: I:
Revision: 3.10
OS device name: I:
Revision: 3.10
PM sent.NCiH85 wrote: Sun Aug 02, 2026 5:39 am Hi Coopervid,
OS device name: I:
Revision: 3.10
Sure email me the makemkv drive info section see belowNCiH85 wrote: Sun Aug 02, 2026 5:39 am Hi ,
OS device name: I:
Revision: 3.10
