Pioneer BDR-XD05TS 4k compatibility?
Re: Pioneer BDR-XD05TS 4k compatibility?
dbirnel wrote:
Thu Jan 22, 2026 7:41 pm
Hi @Coopervid,
I also have one of these drives. Can this be updated to support 4k UHD?
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: #####
Firmware date: 2014-12-26
Highest AACS version: 82
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
PM sent.
comadose
Post by comadose »
OS device name: E:
Revision: 1.20
Serial number: NDDL001132JP
Firmware date: 2013-11-11
Firmware version: 1.20/ID69
Thanks.
comadose wrote:
Fri Jan 23, 2026 9:29 am
Hi @Coopervid, you PMed me some details, but for the '07 drive, not the '05 drive. I can't seem to reply to your PM. Would you mind contacting me? Thanks.
It took you from September 2025 to now to say that you got the wrong files????? And at the same time you are getting in an argument with Billy? I need to say that this is pathetic and that I don't like your attitude. However, you should be able to PM now. Contact me and I will check options - what I don't usually do.
comadose
Post by comadose »
I had some issues. Thanks for being nicer than Billy I guess.
jwwmah
Post by jwwmah »
I also have this drive? What's the secret? Thanks
OS device name: /dev/rdisk1
Current profile: DVD-ROM
Revision: 3.01
Serial number: OGDL062772UC
Highest AACS version: 76
jwwmah wrote:
Tue Feb 24, 2026 2:48 am
Revision: 3.01
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
eroc1990
Post by eroc1990 »
Piling onto the pile with my own request. Also, is it possible to do so from Linux or will I need access to a Windows OS to do this? (I assume a VM will be sufficient, worst case).
OS device name: /dev/sr0
Revision: 3.01
Serial number: <redacted>
Highest AACS version: 81
eroc1990 wrote:
Mon Mar 30, 2026 6:30 pm
Revision: 3.01
PM sent.
comadose
Post by comadose »
Revision: 3.01
PM sent.
comadose wrote:
Mon Mar 30, 2026 7:49 pm
Revision: 3.01
PM sent.
If I respond there is no fee required. I only ask for a donation which is not mandatory. I only asked in your case because you have such a bad attitude.
comadose
Post by comadose »
Coopervid wrote:
Mon Mar 30, 2026 8:05 pm
You object to other people offering help now? Okay, well, you do you I guess. Speaking of bad attitudes... :roll:
comadose wrote:
Mon Mar 30, 2026 8:17 pm
I always provided the flasher without fees until you showed up with your bad attitude. You have a bad personality. And that's it.
comadose
Post by comadose »
Coopervid wrote:
Mon Mar 30, 2026 8:28 pm
Oh, that's not what you told me.
"Pick the number of drives and which and send $25 : 20 Euro per drive to redacted@gmail.com with paypal friends and family."
Because of your fucked up attitude you showed. I never asked anyone before for a fixed fee.
comadose
Post by comadose »
Lovely.
