Hello, Newbie here, I recently bought a USB external Blu ray drive in the hopes of backing up my disks.
This is my drive information from makemkv:
OS device name: J:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: A102
Serial number: **************
Firmware date: 2124-08-05 14:55
Bus encryption flags: 1F
The exact model is this: https://www.amazon.com.au/dp/B07P617CT9 ... title&th=1
I have also installed SDFtool flasher and the "All you need firmware" pack in advance, but I'm not really sure which firmware in the "Slim External Drives" is compatible for my drive.
I want to make sure everything is A-OK and select the right firmware before taking any further steps.
Many Thanks.
New here, would like double checking before flashing drive
bookworm27
Re: New here, would like double checking before flashing drive
its a BU40Nbookworm27 wrote: Sun Mar 29, 2026 12:54 am Hello, Newbie here, I recently bought a USB external Blu ray drive in the hopes of backing up my disks.
OS device name: J:
Manufacturer: ASUS
Revision: A102
Many Thanks.
follow guide steps for that or email me or marty for an auto flasher
bookworm27
Yep, just went through with the rest of the steps, works perfectly fine, thank you.
