LG HL-DT-ST BD-RE BH12LS38 suddenly not working with MakeMKV
I have an LG rom model HL-DT-ST BD-RE BH12LS38 that I had used for quite a while to rip my dvds and BRs. It suddenly would not work with MakeMKV and so I got an external that does. Today I was loading a BR into the external and while it was doing its thing I loaded a BR into the LG drive and it loaded up in another instance of MakeMKV. I have messed around with loading a BR into the external then one into the LG drive and gotten it to function several times. What would be the issue with the LG drive and would some kind of flashing possibly solve it? And if so what would I need to do to fix the issue? The external works but is not as fast as the LG. Thanks in advance.
Re: LG HL-DT-ST BD-RE BH12LS38 suddenly not working with MakeMKV
No, flashing won't help it and there's no flashing available for it anyway.dooleyjlt wrote: Sat Mar 28, 2026 12:47 am I have an LG rom model HL-DT-ST BD-RE BH12LS38 that I had used for quite a while to rip my dvds and BRs. It suddenly would not work with MakeMKV and so I got an external that does. Today I was loading a BR into the external and while it was doing its thing I loaded a BR into the LG drive and it loaded up in another instance of MakeMKV. I have messed around with loading a BR into the external then one into the LG drive and gotten it to function several times. What would be the issue with the LG drive and would some kind of flashing possibly solve it? And if so what would I need to do to fix the issue? The external works but is not as fast as the LG. Thanks in advance.
It would help if you could elaborate on "would not work". That doesn't really tell us anything.
If you have had success with the drive since, it may have just been a particular disc the drive did't like/couldn't read. The disc could have been dirty, scratched etc causing read issues. The drive also may have just needed a reboot. This is all just guesswork as you didn't specify what error you got or what didn't work.
It went from normal operation to when if I have MakeMKV already open it starts spinning the disc and never stops. And as far as functioning now only if I put a Blu-Ray in an external and have it going will the LG Drive at times fire up normally and read a Blu-Ray. But if I start MakeMKV first then insert a BR or have a BR inserted and start up MakeMKV either way it just spins the drive endlessly. I am not sure of what having an external drive going with MakeMKV could have to do with a different BR Rom working here or there.
Yeah, no, you should always let the OS initialise the disc before you open up MakeMKV, at least for the first time of a ripping session.dooleyjlt wrote: Sat Mar 28, 2026 5:02 am It went from normal operation to when if I have MakeMKV already open it starts spinning the disc and never stops. And as far as functioning now only if I put a Blu-Ray in an external and have it going will the LG Drive at times fire up normally and read a Blu-Ray. But if I start MakeMKV first then insert a BR or have a BR inserted and start up MakeMKV either way it just spins the drive endlessly. I am not sure of what having an external drive going with MakeMKV could have to do with a different BR Rom working here or there.
Personally, I always let the OS initialise the disc prior to opening MakeMKV then I close MakeMKV when the rip has completed and repeat the process for each disc I want to rip.
Thanks for the Info, I will try that and see if I can find exactly what order of what processes makes it possible for the drive to work with MakeMKV. As I am sure that information along with all my drive info would be helpful for anyone trying to assist me. Again Thank You
ktownknerd
I too have this drive and am experiencing issues with getting it to work.
If I leave a disc out of the drive and startup MakeMKV it loads fine (Screenshot From 2026-04-20 23-11-22)
When I insert a disc it gets stuck on Disc is being loaded (Screenshot From 2026-04-20 23-12-44)
this is what I see in the log file
Debug log started at Tue Apr 21 03:29:43 2026 , written by MakeMKV v1.18.3 linux(x64-release)
001005:0000 MakeMKV v1.18.3 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/user/MakeMKV_log.txt
Using 768KB for read cache.
001003:0020 DEBUG: Code 0 at `BLLaJX7%0; ?J)zOB:`KC:29393631
No SDF v0a5: TSSTcorp_CDDVDW_SH-S223C_SB01_&_V___________T
SDF id v0a5: TSSTcorp_CDDVDW_SH-S223C_SB01_&_V___________T
No SDF v0a5: HL-DT-ST_BD-RE__BH12LS38_1.03_20131106123456_K9LB5IB4555
SDF id v0a5: HL-DT-ST_BD-RE__BH12LS38_1.03_20131106123456_K9LB5IB4555
SDF auto v0a5: HL-DT-ST_BD-RE__BH12LS38_1.03_20131106123456_K9LB5IB4555
If I remove the disc close down MakeMKV, load the disc in and wait for it to mount in debian, then startup MakeMKV this is what I get (Screenshot From 2026-04-20 23-15-12)
This is what is captured in the logs
Debug log started at Tue Apr 21 03:32:13 2026 , written by MakeMKV v1.18.3 linux(x64-release)
OS: Debian Sid
Version of MakeMKV -
makemkv-bin 1.18.3-1~trixie
makemkv-oss 1.18.3-1~trixie
OS: Debian Sid
- Start MakeMKV with a disc in the drive
- Screenshot From 2026-04-20 23-15-12.png (25.09 KiB) Viewed 12649 times
- insert a disc it gets stuck on Disc is being loaded
- Screenshot From 2026-04-20 23-12-44.png (61.38 KiB) Viewed 12649 times
- leave a disc out of the drive and startup MakeMKV
- Screenshot From 2026-04-20 23-11-22.png (51.63 KiB) Viewed 12649 times
There have been reports that the latest version doesn't work or work well with non-LibreDrive. Try an older version of MakeMKV such as 1.17.7 and/or 1.17.6 and see if it makes a difference.
