Pioneer bdr 209 and Pioneer bdr 209m
fox8091
Re: Pioneer bdr 209 and Pioneer bdr 209m
Post by fox8091 » Fri Mar 27, 2026 6:24 pm
Not able to initiate PMs yet, but I'd appreciate a flasher. Drive info below:
OS device name: H:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.10
Serial number: <snip>
Firmware date: 2013-09-10
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.10/ID61
Post by Billycar11 » Sat Mar 28, 2026 2:22 pm
fox8091 wrote: Fri Mar 27, 2026 6:24 pm Not able to initiate PMs yet, but I'd appreciate a flasher. Drive info below:
OS device name: H:
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Post by Coopervid » Sun Mar 29, 2026 8:47 pm
OS device name: H:
Revision: 1.10
PM sent.
chris-rg
Post by chris-rg » Wed Apr 01, 2026 1:30 pm
Hi all,
also being intrested if I can upgarde my drive:
Product: BD-RW BDR-209M
Revision: 1.34
Serial number: PLDL043627WL
Firmware date: 2016-04-25
Firmware version: 1.34/ID60
Thanks a lot!
Post by Billycar11 » Wed Apr 01, 2026 2:18 pm
chris-rg wrote: Wed Apr 01, 2026 1:30 pm Hi all,
Revision: 1.34
Thanks a lot!
see below for email
Post by Coopervid » Wed Apr 01, 2026 4:38 pm
Revision: 1.34
Thanks a lot!
Reload your browser.
Snitchy
Post by Snitchy » Sat May 30, 2026 11:25 am
Hi @Coopervid,
I hope you are doing well.
I recently got a Pioneer BDR-209M drive and would like to ask if this drive can be made UHD-friendly. If yes, could you please help me with the correct flashing approach?
MakeMKV reports the drive as:
Revision: 1.34
Highest AACS version: 82
I would rather ask before trying anything risky myself, since I do not want to flash an incompatible firmware.
I currently cannot send PMs yet, but I can provide the serial number or any additional information as soon as PMs are available for my account.
Thank you very much for your help.
Post by Coopervid » Sat May 30, 2026 8:05 pm
Snitchy wrote: Sat May 30, 2026 11:25 am Hi @Coopervid,
Revision: 1.34
PM sent but thr forum is super slow. Not my fault.
Post by Billycar11 » Sun May 31, 2026 4:35 am
no need to post your info here publicly just reach out to me directly
see below for email
Snitchy
Post by Snitchy » Sun May 31, 2026 12:13 pm
Coopervid wrote: Sat May 30, 2026 8:05 pm
Revision: 1.34
Hi Coopervid,
thank you very much for your PM, the files and the tutorial.
Unfortunately I currently cannot reply to PMs, so I hope it is okay to answer here.
I followed your instructions and the BDR-209 flash worked perfectly. The drive is now detected as a BDR-S11 / BDR-211 and UHD discs work in MakeMKV. I also sent a donation via PayPal as a thank you.
I wanted to ask if you could also help me with another Pioneer drive, a slim BDR-UD03. I am trying to find out whether it can be crossflashed to enable UHD support as well.
MakeMKV reports it as:
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
If this drive can be made UHD capable, I would really appreciate your advice.
Thank you again for your help.
Post by Coopervid » Mon Jun 01, 2026 12:59 pm
Will send another PM but the forum is horribly slow.
Snitchy
Post by Snitchy » Mon Jun 01, 2026 5:39 pm
Coopervid wrote: Mon Jun 01, 2026 12:59 pm Will send another PM but the forum is horribly slow.
Hi Coopervid,
thank you very much for your help and for sending the files/tutorial.
Unfortunately I still cannot reply to PMs directly, so I am replying here.
The UD-03 flash worked perfectly!
Thanks again for sharing the files and the clear instructions. Much appreciated!
Post by Coopervid » Mon Jun 01, 2026 6:57 pm
Snitchy wrote: Mon Jun 01, 2026 5:39 pm
Hi Coopervid,
You are very welcome!
BlamWungus
Post by BlamWungus » Sat Jun 06, 2026 6:34 pm
Hi! I've been lurking for a while in the hopes I would eventually get a flashable drive. I snatched this one without really thinking. Hope it's flashable.
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Highest AACS version: 16
Firmware version: 1.20/ID61
Post by Billycar11 » Sun Jun 07, 2026 2:25 am
BlamWungus wrote: Sat Jun 06, 2026 6:34 pm Hi! I've been lurking for a while in the hopes I would eventually get a flashable drive. I snatched this one without really thinking. Hope it's flashable.
Revision: 1.20
Serial number:
see below for email
