Hello everyone,
I got a question regarding Pioneer drives. In the last few weeks I got a hand on 8 Pioneer drives in external ASUS enclosures, 4 of them are BDR-209MBK and 4 of them should be BDR-212T according to MakeMkv. The BDR-209MBK were flashed by me to the S11J and the BDR-212T to BDR-S12U.
If I take a look into the device information provided by the flasher the BDR-209MBK are listed as 209MBK with drive platform RS8800, in MakeMkv they appear after the flash as a S11.
But if I take a look into the device information provided by the flasher for the BDR-212T they are all listed as BDR-209MBK too, but with an other drive platform (RS8F01). In MakeMkv they appear all as RS8F01 too, product is not the BDR-S12U, Firmware name is BDR-212T. All of them were manufactured between August 2023 and August 2024.
According to some research in this forum RS8F01 is the newer platform for BDR-S12U and BDR-212.
I shucked one of the drives with a BDR-212T in it and the drive is a BDR-209MBK like the flasher said.
So is it indeed a BDR-209MBK with firmware of the BDR-212?
Best, D3619
BDR-212T/BDR-209MBK
Re: BDR-212T/BDR-209MBK
No. Some 212s are sold as 209s. You just look at the hardware platform. 209s are either 8600 or 8601. To flash them you need the appropriate firmware 8800 or 8801. 212s are either 8F00 or 8F01. Both can be flashed to UHD with the 8F01 firmware.D3619 wrote: Fri Mar 27, 2026 12:31 pm Hello everyone,
Best, D3619
Firmware on the drives must be older than Dec. 2022.
i can now flash 12/22+ drives if you need that email me see belowD3619 wrote: Fri Mar 27, 2026 12:31 pm Hello everyone,
Best, D3619
OneDay
I can confirm for Billycar11. My BDR-XD05W with a flash date of 3/02/2023 was locked from reading UHD. Now it is reading and ripping. Billycar11 process is very quick. Thank you.i can now flash 12/22+ drives if you need that email me see below
D3619
Ah okay. Hardware from a 212 labeled as 209. Got it.Coopervid wrote: Fri Mar 27, 2026 12:49 pmNo. Some 212s are sold as 209s. You just look at the hardware platform. 209s are either 8600 or 8601. To flash them you need the appropriate firmware 8800 or 8801. 212s are either 8F00 or 8F01. Both can be flashed to UHD with the 8F01 firmware.D3619 wrote: Fri Mar 27, 2026 12:31 pm Hello everyone,
Best, D3619
Thank you!
D3619
There is one more question I have now:Coopervid wrote: Fri Mar 27, 2026 12:49 pmNo. Some 212s are sold as 209s. You just look at the hardware platform. 209s are either 8600 or 8601. To flash them you need the appropriate firmware 8800 or 8801. 212s are either 8F00 or 8F01. Both can be flashed to UHD with the 8F01 firmware.D3619 wrote: Fri Mar 27, 2026 12:31 pm Hello everyone,
Best, D3619
My other BDR-209MBK are drive platform RS8800. So there are at least 3 generations of Pioneer drives sold as 209s? 8600/8601, 8800/8801 and 8F00/8F01?
And 8600/8601 is equivalent to BDR-209 (real 209s)?
8800/8801 is equivalent to BDR-211?
And 8F00/8F01 is equivalent to BDR-212 according to your post.
yodalf
Hi guys,
I've got the following drive:
Is this drive capable of getting crossflashed to support UHD discs? Thanks in advance for any help.
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: xxxx
Firmware date: 2020-07-21
Highest AACS version: 82
Platform Drive: RS8F00
Firmware version: E116/ID71
sure email me that info and all others email me no need to post your info here just reach out to me directlyyodalf wrote: Sat Mar 28, 2026 1:39 pm Hi guys,
Is this drive capable of getting crossflashed to support UHD discs? Thanks in advance for any help.Code: Select all
Drive Information Manufacturer: ASUS Product: BW-16D1H-U Revision: E116 Serial number: xxxx Firmware date: 2020-07-21 Bus encryption flags: 1B Highest AACS version: 82 LibreDrive Information Status: Enabled Platform Drive: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: E116/ID71 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
see below for email
Correct.D3619 wrote: Sat Mar 28, 2026 1:28 pmThere is one more question I have now:Coopervid wrote: Fri Mar 27, 2026 12:49 pmNo. Some 212s are sold as 209s. You just look at the hardware platform. 209s are either 8600 or 8601. To flash them you need the appropriate firmware 8800 or 8801. 212s are either 8F00 or 8F01. Both can be flashed to UHD with the 8F01 firmware.D3619 wrote: Fri Mar 27, 2026 12:31 pm Hello everyone,
Best, D3619
thirdbyte406
Hello, I recently acquired a Pioneer BDR-212DBK drive with the following firmware info in MakeMKV:
I wanted to know if there was a guide on how to cross-flash these directly myself if that was possible?
As I have seen that billy offers this as a remote service specifically if you do not want to but I wondered if a type of software for flashing Pioneers exists alongside the specific firmware files needed?
Thank you.
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.00
Serial number: TJDL026030WL
Firmware date: 2019-01-10
Bus encryption flags: 13
Highest AACS version: 12
Drive platform: RS8F00
Firmware version: 1.00/ID61
Thank you.
see below for email
see below for email
PM sent.thirdbyte406 wrote: Thu Apr 23, 2026 12:37 pm Hello, I recently acquired a Pioneer BDR-212DBK drive with the following firmware info in MakeMKV:I wanted to know if there was a guide on how to cross-flash these directly myself if that was possible?Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-212D Revision: 1.00 Serial number: TJDL026030WL Firmware date: 2019-01-10 Bus encryption flags: 13 Highest AACS version: 12 LibreDrive Information Status: Enabled Drive platform: RS8F00 Firmware name: PIONEER BDR-212T Firmware type: Original (unpatched) Firmware version: 1.00/ID61 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Thank you.
lleh21
Hi, Can someone please PM me the link to the files for BDR-212DBK Thanks!
Subject: BDR-212T/BDR-209MBK
see below for email
see below for email
