Something Interesting about this drive BDW-PR1EPDVPP100
OneDay
Post by OneDay »
So I took a chance on ebay and bought a Pioneer BDW-PR1EPDVPP100. I Just received the drive today. Hooked it up and opened Makemkv to find out it has been flashed or look like it has been flashed to BDR-209. Seeing this I was wondered how they did this since from what I have read there is no way to flash these drives. So I put a blu ray in to see how fast these drives rip. Well I get not disc inserted. So I unplugged the drive and re connected it and still nothing. So now I'm sure this things is toast or bricked supper hard. What are you thoughts? Here is the info Makemkv shows
OS device name: F:
Manufacturer: PIONEER
Product: BDW-PR1EPDVPP100
Revision: 1.00
Serial number:
Firmware date: 2015-11-27
Highest AACS version: 70
Drive platform: RS8680
Firmware version: 1.00/ID79
skyrider
Re: Something Interesting about this drive BDW-PR1EPDVPP100
Post by skyrider »
It has no equivalent in Pioneer's retail lineup.
This drive was most likely developed specifically for Seiko Corp. (Epson).
Technically, it uses hardware very similar to the Pioneer BDR‑209/S09 - the same ONP‑8342A mainboard and the Renesas R8J32740FP42 chipset.
The only differences are OPU and different firmware. It writes DVD and CD media, while Blu‑ray discs are read‑only (it's combo drive).
Pioneer designated the hardware as SAT8680.
There's nothing you can do with it in terms of UHD support / BD writing.
Looking for a Pioneer 4K UHD drive?
Click here
skyrider wrote: Thu Mar 26, 2026 10:22 pm It has no equivalent in Pioneer's retail lineup.
Correct.
OneDay
Post by OneDay »
Is the hardware set in the Renesas R8J32740FP42 chipset?
OPU? Not sure what is?
I think I might just swap out the Renesas chip. I have a donor BDR-209 that I can de solder and solder it on the BDW-PR1. See what happens.
skyrider
Post by skyrider »
OPU = Optical Pickup Unit.
In my opinion, this swap won't work, if only because it uses different software.
If you can, return this drive. It was probably taken out of a damaged Epson DiscProducer duplicator.
Click here
OneDay
Post by OneDay »
Sending it back.
Thank You
