Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
can my Pioneer be flashed ?
OS device name: M:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.54
Serial number: XXXXXXXXXXXX
Firmware date: 2020-07-21
Drive platform: RS8600
Firmware version: 1.54/ID43
THX and BR
OS device name: M:
Revision: 1.54
THX and BR
sure email me that info and all others email me no need to post your info here just reach out to me directlyPumpkin wrote: Wed Feb 25, 2026 9:35 pm Hi,
OS device name: M:
Revision: 1.54
THX and BR
see below for email
Hello. Just got this drive:
Can this be flashed? Thanks <3
OS device name: G:
Revision: 1.10
Serial number: MLDL002787WL
Firmware date: 2013-10-15
Firmware version: 1.10/ID43
sure email me that infolevtrocki wrote: Thu Mar 26, 2026 5:56 pm Hello. Just got this drive:
Can this be flashed? Thanks <3Code: Select all
Drive Information OS device name: G: Manufacturer: PIONEER Product: BD-RW BDR-S09 Revision: 1.10 Serial number: MLDL002787WL Firmware date: 2013-10-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.10/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
see below for email
Yes. I provide the flasher and only ask for a donation and no fee.levtrocki wrote: Thu Mar 26, 2026 5:56 pm Hello. Just got this drive:
I have the same drive, can you PM me?Coopervid wrote: Thu Mar 26, 2026 10:22 pmYes. I provide the flasher and only ask for a donation and no fee.levtrocki wrote: Thu Mar 26, 2026 5:56 pm Hello. Just got this drive:
PM sent.yapmkv wrote: Sat Mar 28, 2026 9:30 pmI have the same drive, can you PM me?Coopervid wrote: Thu Mar 26, 2026 10:22 pmYes. I provide the flasher and only ask for a donation and no fee.levtrocki wrote: Thu Mar 26, 2026 5:56 pm Hello. Just got this drive:
what a fascinating topic! For some inexplicable reason (laziness, I suppose), I completely missed all of this. Well, to make a long story short, I have the following three drives in my home:
The first and second one (only the serial number is different):
Revision: 1.51
Serial number: 000000000000
Firmware date: 2018-05-08
Highest AACS version: 81
Drive platform: RS8601
Firmware version: 1.51/ID43
The third one:
Product: BD-RW BDR-XU03
Revision: 1.03
Firmware date: 2015-06-29
Bus encryption flags: 13
Drive platform: RS8520
Firmware version: 1.03
I have no idea if that matters, but we only have two Macs (one with an Intel chip and one with an Apple/ARM chip) and no Windows systems. Would that work?
Revision: 1.51
The third one:
Revision: 1.03
You need windows or a VM for it to worknexttoyou wrote: Sun Jun 28, 2026 5:46 pm Hi,
Revision: 1.51
The third one:
Revision: 1.03
Sure email me that drive info section see below for email
PM sent for your 209. The other one isn't flashable for UHD:nexttoyou wrote: Sun Jun 28, 2026 5:46 pm Hi,
Revision: 1.51
The third one:
Revision: 1.03
Thank you very much! It all looks pretty simple. I'm going to use a VM on my iMac (Intel) for this.Coopervid wrote: Sun Jun 28, 2026 9:19 pm PM sent for your 209. The other one isn't flashable for UHD:
Just one more question: the two BD-RW BDR-S09 drives are in an external enclosure from OWC (Mercury Pro). As I understand it, the process works without any problems with this enclosure, right?
THX!
Correct.nexttoyou wrote: Mon Jun 29, 2026 1:06 pmThank you very much! It all looks pretty simple. I'm going to use a VM on my iMac (Intel) for this.Coopervid wrote: Sun Jun 28, 2026 9:19 pm PM sent for your 209. The other one isn't flashable for UHD:
THX!
black_raven
found this thread and understood that maybe not all hope is lost for my old Pioneer BDR-S09XLT
It was my first UHD drive but after negative answer from official Pioneer support about reading 4K discs I put it back in the box and bought Asus
Would anyone please help me with the magical firmware needed for 4K discs reading?
Thank you very much in advance
OS device name: F:
Revision: 1.32
Serial number: OEDLXXXXXXWL
Firmware date: 2015-08-25
Highest AACS version: 61
Firmware version: 1.32/ID43
No disc insertedAM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
sure email me that infoblack_raven wrote: Sat Jul 04, 2026 4:47 am Hi,
It was my first UHD drive but after negative answer from official Pioneer support about reading 4K discs I put it back in the box and bought Asus![]()
Drive Information OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-S09 Revision: 1.32 Serial number: OEDLXXXXXXWL Firmware date: 2015-08-25 Bus encryption flags: 1B Highest AACS version: 61 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.32/ID43 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
see below for email
PM sent.black_raven wrote: Sat Jul 04, 2026 4:47 am Hi,
