Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
anon.eh.mous.user wrote: Thu Mar 26, 2026 12:18 pm I figured out the problem. My ISP blocks downloading the HKs, so even though I had the latest keydb.cfg, out of date HKs was causing the problem. I had to use a VPN to successfully download the latest HKs and then the disc rips. I will follow that process in the future. Thanks again!
I'm glad to hear you were able to rip your discs. But if the keydb.cfg file were correctly installed you wouldn't actually need the latest HK files to rip those discs. The keydb.cfg file and the native MakeMKV HKs perform equivalent functions, so I'd recommend trying to sort that out when you get a chance.
anon.eh.mous.user
Post by anon.eh.mous.user »
keydb_helper wrote: Thu Mar 26, 2026 12:35 pm
Will do.
anon.eh.mous.user
❯ curl -o keydb.zip -L0 "http://fvonline-db.bplaced.net/fv_download.php?lang=eng"
  % Total    % Received % Xferd  Average Speed  Time    Time    Time   Current
                                 Dload  Upload  Total   Spent   Left   Speed
  0      0   0      0   0      0      0      0                              0
100 21.10M 100 21.10M   0      0  33312      0   11:04   11:04          38728
❯ unzip ./keydb.zip
Archive:  ./keydb.zip
  inflating: keydb.cfg
❯ mv ./keydb.cfg ~/.MakeMKV
❯ cat ~/.MakeMKV/keydb.cfg | grep "0xD0B73588A895ED9A8CE4FEF68A0A2ABA9AA95754"
0xD0B73588A895ED9A8CE4FEF68A0A2ABA9AA95754 = STRANGENEWWORLDS_SEASON3 (Star Trek: Strange New Worlds - Season 3 (Disc 1)) | D | 2026-03-05 | M | 0x3BF37B428418F8F90633CD3D184F9BF8 | I | 0x0BE6636E316B52B02F5ADD21BE67E67D | V | 0x163ECB52D73734626867B203B972EA81 | U | 1-0x8CFBB695D0A2D17B04733F4CDED92F49 ; MKBv82/BEE/FindVUK 1.82 - VolumeSize: 95952961536 (UHD)
Should be good to go, correct?
keydb_helper
anon.eh.mous.user wrote: Thu Mar 26, 2026 12:59 pm Should be good to go, correct?
Could you please post the output of running:
ls -l ~/.MakeMKV/
If you changed your MakeMKV data directory so that disc dump files aren't being written to that folder you'll need to move the keydb.cfg file accordingly.
barnstarmer wrote: Wed Mar 25, 2026 7:27 pm @keydb_helper
Is it okay to submit discs that already are in the database, but only have the UK and no VUK?
Hey barnstarmer, that is a fair question. My intention with this thread is to ensure the public keydb has as many 'complete' records as possible. A complete record contains all four of the media key, volume ID, volume unique key, and unit key(s).
So if the public keydb has a unit key-only record, or a volume ID + unit key record, or any other combination of records other than my definition of 'complete' I'm happy for the dump file and MKB_RO.inf file to be posted to this thread.
Regardless of a discs keydb status, I still recommend users take the time to email their disc dump files to MakeMKV team. The forum team have been nice enough to allow this thread and I don't want the public keydb to compromise the continued growth of MakeMKV's native title support.
99gagamel
Post by 99gagamel »
Disc Type: UHD
Disc ID: 0xECD702E3C3C14AC2DD6B20D57B5C3AE4F6EAAEA8
Disc Dump Filename: MKB20_v82_Geschichten_aus_der_Schattenwelt_96CF,tgz
Drive: BW-1601HT
Drive Firmware: 3.01
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1pRt_CI ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1Z_MEzi ... sp=sharing
Unit Keys (1):
[1] 0x582FAF23C545B1C82D4135183C08E54C
KeyDB Status:
Status : not found
anon.eh.mous.user
keydb_helper wrote: Thu Mar 26, 2026 1:54 pm
ls -l ~/.MakeMKV/
❯ ls -lah ~/.MakeMKV
total 75M
drwxrwxr-x 1 myusername myusername  182 Mar 26 09:48 .
drwxr-x--- 1 myusername myusername 1.7K Mar 26 09:48 ..
-rw------- 1 myusername myusername  60M Mar 26  2026 keydb.cfg
-rw-rw-r-- 1 myusername myusername 2.0M Jan  7 11:20 makemkv_sdf.bin
-rw-rw-rw- 1 myusername myusername  15K Jan 24 13:42 MKB_v8_save.tgz
-rw-rw-rw- 1 myusername myusername  13M Mar 25 16:16 _private_data.tar
-rw-rw-rw- 1 myusername myusername  594 Mar 25 16:16 screen.conf
-rw-rw-rw- 1 myusername myusername  636 Mar 25 16:12 settings.conf
-rw-rw-rw- 1 myusername myusername  194 Mar 25 16:13 update.conf
Note: I deleted the disc dumps after I shared them with you - but they were in this directory. Also, username redacted.
Pretty sure I should be fine going forward. Probably just a user error the first time I downloaded the keydb.cfg and couldn't rip those 3 discs. I'll be sure to confirm the disc isn't present in the db and the HKs are updated before I submit again in the future. I'm going to write a shell script to download the latest, unpack, grep to confirm the disc isn't present, and run makemkvcon to confirm it can't decrypt. I'll share the source for anyone else who wants to use it / modify it for their use.
Thanks again!
MrPenguin
Post by MrPenguin »
anon.eh.mous.user wrote: Thu Mar 26, 2026 2:59 pm
total 75M
You're using Linux, so the file literally needs to be named "KEYDB.cfg", and not "keydb.cfg".
anon.eh.mous.user
MrPenguin wrote: Thu Mar 26, 2026 3:05 pm
total 75M
Ah, THAT's why it didn't pick it up. The first time I updated the db, I copied the file twice into that directory, one lowercase, one uppercase - and it worked to rip the UK version of The Astronaut. I didn't do that when I tried these 3 discs. Good to know. I'll make sure the script I write accounts for that. Thanks!
Toad King
Post by Toad King »
total 75M
That's not correct. I'm running Linux and it works fine even if I use "keydb.cfg" and not "KEYDB.cfg", at least when put in the MakeMKV folder.
MrPenguin
Post by MrPenguin »
Toad King wrote: Thu Mar 26, 2026 10:41 pm That's not correct. I'm running Linux and it works fine even if I use "keydb.cfg" and not "KEYDB.cfg", at least when put in the MakeMKV folder.
Well, it apparently wasn't working, and there wasn't any other possibility... Which file-system are you using for your .MakeMVK folder? Are you using ext4 with "casefold" enabled?
gregde
Return of the Pink Panther UHD
Post by gregde »
Disc type: UHD
Disc ID: 0x 38e155f366f5816db500147c211f2a602e69fa17
Disc dump filename: MKB20_v82_The_Return_of_the_Pink_Panther_9CF8.tgz
Drive: BD-RE-BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/17QKrsz ... share_link
Disc dump link: https://drive.google.com/file/d/1lNW7mI ... share_link
avaka_71
Post by avaka_71 »
Dumps for
Starship troopers traitor of the mars
hard target
blazing saddles
https://uploadnow.io/f/ckSfMCz
Toad King
Post by Toad King »
MrPenguin wrote: Thu Mar 26, 2026 10:53 pm
btrfs, no case folding.
hamsterdance
Post by hamsterdance »
Disc type: UHD
Disc ID: 0xf4d69fb80370e3fc4cc4103f8c3a5ed366891294
Disc dump filename: MKB20_v82_Dogma_UHD_9393.tgz
Drive: LG BP50NB40
Drive firmware: 1.02 (2120-05-07 09:35)
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://filebin.net/6ucjcvs3p8tvep31/MKB_RO.inf
Disc dump link: https://filebin.net/6ucjcvs3p8tvep31/MK ... D_9393.tgz
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
MKB20_v76_Hard_Target_58E1
MKB20_v77_Blazing_Saddles_9A55
*MKB20_v82_The_Return_of_the_Pink_Panther_9CF8
avaka_71 wrote: Thu Mar 26, 2026 11:32 pm Dumps for
hard target
blazing saddles
Hey avaka_71, you'll need to provide the full MKB_RO.inf file from the discs AACS folder in order for Starship Troopers: Traitor of Mars to be added to the public keydb. The MKB_RO.inf file in your disc dump was not the full file, so please don't extract it from the TGZ file and upload it. The full MKB_RO.inf should be at least several megabytes in size. If anything is unclear, please read the opening post of this thread.
(Your other two titles utilise media keys which are already known to the public keydb, so nothing else is required for Hard Target or Blazing Saddles)
