Can't setup Integration with VLC in Preferences
whitedb
Post by whitedb » Thu Oct 16, 2025 5:39 pm
I am trying to play a BluRay in VLC using the integration option in the MakeMKV preferences. With a disc loaded in MKV I can open the preferences and then click in the tab for integration. I then select the box for VLC and click apply.
I get a dialogue box asking for my admin password which I enter. The dialogue box disappears but the settings are not changed. The blue tick for VCL disappears and if I close the preferences and re-open them the integration with VLC is still not checked. This is confirmed when I try to play a Bluray in VLC and I get the error. "This Blu-ray Disc needs a library for AACS decoding, and your system does not have it."
Any suggestions on how to fix this or a better way to enable Bluray playback in VLC?
VLC: 1.18.2 running on a MacStudio on Sequoia
Re: Can't setup Integration with VLC in Preferences
Post by dcoke22 » Fri Oct 17, 2025 4:43 pm
VLC needs a symlink to the libmmbd library that comes with MakeMKV. Sometimes MacOS's security model messes it up. You might be able to create the appropriate link manually.
Direct Blu-ray playback with VLC player
Leberkasbepi
Post by Leberkasbepi » Tue Oct 21, 2025 5:13 am
dcoke22 wrote: Fri Oct 17, 2025 4:43 pm VLC needs a symlink to the libmmbd library that comes with MakeMKV. Sometimes MacOS's security model messes it up. You might be able to create the appropriate link manually.
Is there a instruction how to do that?
hanshotfirst1138
Post by hanshotfirst1138 » Wed Nov 05, 2025 9:53 pm
I checked all the boxes and it’s still not working for me.
jabba359
Post by jabba359 » Sat Nov 08, 2025 1:36 am
I'm having the same issue and can't figure out how to get my MakeMKV permissions to stick.
joetheripper
Post by joetheripper » Tue Jan 20, 2026 3:54 pm
Same issue. I created the symlinks according to the old manual instructions, but wondering if they'll work any more with 1.18.2?
Also, there are now TWO libraries delivered with MakeMKV: xxx_new.dylib and xxx_old.dylib. Which one should be symlinked?
Is there a better location to create the symlinks other than ${HOME}/lib ?
UPDATE: I got it working by creating the symlinks in /usr/local/lib. I used the xxx_new.dylib versions.
kitzlle
Post by kitzlle » Wed Feb 04, 2026 7:48 pm
joetheripper wrote: Tue Jan 20, 2026 3:54 pm Same issue. I created the symlinks according to the old manual instructions, but wondering if they'll work any more with 1.18.2?
could you explain this like I'm five?
what are the new terminal commands?
kitzlle
Post by kitzlle » Sun Mar 22, 2026 6:55 am
nevermind this, it just works right with the most recent update. (for me at least)
marcador
Post by marcador » Wed Mar 25, 2026 7:26 pm
kitzlle wrote: Sun Mar 22, 2026 6:55 am nevermind this, it just works right with the most recent update. (for me at least)
You're a nice one, huh?! Me, me ,me...🫶🏻
