[Windows] MakeMKV crashing when hard drive busy
crowfax
#1 Post by crowfax » Thu Apr 05, 2012 2:14 am
I noticed the other day when I booted into Windows 7 and loaded MakeMKV that it crashed right after loading, the fatal error and program exiting crash. I opened it again and it worked fine. Today, I was remuxing a file with MKVmergeGUI and opened MakeMKV, the same thing happened again. I tried opening it again, and it crashed a second time; then a third and fourth. The moment I stopped MKVmergeGUI from running, it opened fine. Following a hunch, I then started a file copy on my C:\ and tried opening MakeMKV again, once more it crashed.
It seems that MakeMKV crashes whenever the drive it's loading from is under heavy load, I've not noticed this behavior in the Linux version, so it seems to be Windows (and perhaps Windows 7 64-bit) specific.
Has anyone else noticed similar behavior? Is anyone able to try and replicate the issue? Just start copying a huge file from your C:\ to another location on your C:\, then load MakeMKV and see if it opens, or crashes.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
Re: [Windows] MakeMKV crashing when hard drive busy
#2 Post by mike admin » Fri Apr 06, 2012 9:21 am
Please do this - http://www.makemkv.com/onlinehelp/dump.html . It's a lengthy step but without it it's impossible to figure out what's going on.
twa000
#3 Post by twa000 » Fri Apr 06, 2012 11:22 am
crowfax wrote:I noticed the other day when I booted into Windows 7 and loaded MakeMKV that it crashed right after loading, the fatal error and program exiting crash. I opened it again and it worked fine. Today, I was remuxing a file with MKVmergeGUI and opened MakeMKV, the same thing happened again. I tried opening it again, and it crashed a second time; then a third and fourth. The moment I stopped MKVmergeGUI from running, it opened fine. Following a hunch, I then started a file copy on my C:\ and tried opening MakeMKV again, once more it crashed.
Just tried this running win 7 64. Copied large files from C to C, also in parallel ran my satellite TV program (large memory user) and Makemkv - no problems.
Sounds more like a driver conflict problem or bad disk (have you tried cleaning up and checking your C drive for problems?)
crowfax
#4 Post by crowfax » Fri Apr 06, 2012 2:53 pm
twa000 wrote:Just tried this running win 7 64. Copied large files from C to C, also in parallel ran my satellite TV program (large memory user) and Makemkv - no problems.
Just to be clear, you started all the other processes, then opened MakeMKV? Also, can you try booting from cold, then directly after login while your HDD is still grinding, try loading MakeMKV.
mike admin wrote:Please do this - http://www.makemkv.com/onlinehelp/dump.html . It's a lengthy step but without it it's impossible to figure out what's going on.
Will do now.
crowfax
#5 Post by crowfax » Fri Apr 06, 2012 3:18 pm
I've PM'd the dump file to you Mike.
twa000
#6 Post by twa000 » Sat Apr 07, 2012 2:08 pm
.[/quote]
Yes - will try the other request if I ever get my Outlook system back, made the stupid mistake of trying to sync to Apple's iCloud
crowfax
#7 Post by crowfax » Sat Apr 07, 2012 4:41 pm
Thanks, I appreciate it.
