American dad from season 9 to 14 region Mkv fails to make iso
But can make mkv files in disk mode
those dvds are made by Aple software and the vob files with the episodes are in hiden mode.
Other tools also fail to make iso from them (from iso buster to magic Iso and ImgBurn9
Some crash in the first place (xreveal)
for some reason Mkv manage to deal with this and for some reason also can not make iso.
i put here the log so you cam improve mkv.
hope the info of the log file helps you guys
experiment1
MakeMKV v1.18.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Logos/MakeMKV_log.txt
udf: udf_get_node: bad allocation extension size in udf_node
DEBUG: Code 0 at Xw{s,khI_PQ|v>x3>:213130283
Backing up disc into folder "O:/Video/backup/AMERICAN_DAD_V14_D2.iso"
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 236 at X_Q`2"KJuGp@<O:121273020
Calculated BUP offset for VTS #3 does not match one in IFO header.
DEBUG: Code 2 at X_Q`2"KJuGp@<O:213131755
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
DEBUG: Code 10 at b\F`elXrU2U~2;C%w:213131318
DBG ASSERT: QuV3pT=F^T?ipK%y2vbd17"Zs*RZc3\*qA4 at X_Q`2"KJuGp@<O:29402003
Calculated BUP offset for VTS #10 does not match one in IFO header.
DEBUG: Code 118095996 at &zUO>=0yYM*;qG%t8r#+X\b:29394183
DEBUG: Code 0 at &zUO>=0yYM*;qG%t8r#+X\b:121263590
DEBUG: Code 0 at 7#MR{@HBo.ez7ec]o9Uy:29394689
DEBUG: Code 3221225649 at QpU860LV{}|}B]j|,_$%hs :29394919
DEBUG: Code 3221225649 at &zUO>=0yYM*;qG%t8r#+X\b:213130145
DEBUG: Code 3221225480 at QpU860LV{}|}B]j|,_$%hs :121262509
DEBUG: Code 3221225480 at &zUO>=0yYM*;qG%t8r#+X\b:29394183
DEBUG: Code 0 at g|Td]xYm%Lw_)*:29397104
DEBUG: Code 0 at z[K#?gp7+1^1<Yx='Q*F:121266097
Backup failed
experiment 2
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Backup failed
Backup failed
Title #1 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Can't locate a cell for VTS 3 TTN 1 PGCN 0 PGN 0
Title #3 was added (5 cell(s), 0:21:06)
Title #4 was added (5 cell(s), 0:21:06)
Can't locate a cell for VTS 4 TTN 1 PGCN 0 PGN 0
Title #5 was added (5 cell(s), 0:21:05)
Title #6 was added (5 cell(s), 0:21:05)
Can't locate a cell for VTS 5 TTN 1 PGCN 0 PGN 0
Title #7 was added (5 cell(s), 0:21:06)
Title #8 was added (5 cell(s), 0:21:06)
Can't locate a cell for VTS 6 TTN 1 PGCN 0 PGN 0
Title #9 was added (5 cell(s), 0:21:05)
Title #10 was added (5 cell(s), 0:21:05)
Can't locate a cell for VTS 7 TTN 1 PGCN 0 PGN 0
Title #11 was added (5 cell(s), 0:21:06)
Title #12 was added (5 cell(s), 0:21:06)
Can't locate a cell for VTS 8 TTN 1 PGCN 0 PGN 0
Title #13 was added (5 cell(s), 0:21:06)
Title #14 was added (5 cell(s), 0:21:06)
Can't locate a cell for VTS 9 TTN 1 PGCN 0 PGN 0
Title #15 was added (5 cell(s), 0:21:05)
Title #16 was added (5 cell(s), 0:21:05)
Can't locate a cell for VTS 10 TTN 1 PGCN 0 PGN 0
Title #17 was added (5 cell(s), 0:21:06)
Title #18 was added (5 cell(s), 0:21:06)
Title #18 with special attributes was skipped
Title #19 with special attributes was skipped
Title #04 in VTS 3 is equal to title #03 and was skipped
Title #06 in VTS 4 is equal to title #05 and was skipped
Title #08 in VTS 5 is equal to title #07 and was skipped
Title #10 in VTS 6 is equal to title #09 and was skipped
Title #12 in VTS 7 is equal to title #11 and was skipped
Title #14 in VTS 8 is equal to title #13 and was skipped
Title #16 in VTS 9 is equal to title #15 and was skipped
Title #18 in VTS 10 is equal to title #17 and was skipped
Saving 8 titles into directory O:/Video/backup
