makemkv hangs, makemkvcon at 100%
nordwand
#1 Post by nordwand » Wed Mar 25, 2026 11:51 am
Hi all
MakeMKV v1.18.3 (new compiled)
Registered user.
Arch Linux up to date
I am trying to rip a BD, but the main MakeMKV window has "Scanning CD-ROM devices" at 100% and hangs there.
There is a process "makemkvcon" that eats 100% CPU time, which seems what the frontend is waiting for.
I can confirm that with 1.18.3 on Windows, with the same BD reader and BD disk, there are no issues.
Any ideas?
science-nerd
Re: makemkv hangs, makemkvcon at 100%
#2 Post by science-nerd » Mon Mar 30, 2026 9:06 pm
Is your sg kernel module loaded?
You can load it for the current session via modprobe:
sudo modprobe sg
tomty89
#3 Post by tomty89 » Wed Apr 08, 2026 11:40 pm
In my experience, occasionally with some drives / discs, one could bump into this kind of hang issue if you inserted the disc *before* makemkv is started.
librelibre
#4 Post by librelibre » Thu Apr 09, 2026 3:24 am
What do your system logs say? Or makemkv log?
nordwand
#5 Post by nordwand » Mon Apr 13, 2026 6:33 pm
Thanks everyone, and sorry for the late reply, we had holidays here.
When I first start makemkv, and then load the disc, it hangs indefinitely in the "Type: Loading ..." Label: Please wait" state
makemkv log shows nothing, just "MakeMKV v1.18.3 linux(x64-release) started"
System logs (journallog) gives nothing related to device loading etc.
Yes it is:
$ lsmod | grep sg
sg                     53248  6
I have doubted that my bluedisc support libraries are problematic, but I had no problem playing the disc using smplayer directly from the drive.
Thanks for any further suggestions!
nuts_fulgurates
#6 Post by nuts_fulgurates » Sat May 09, 2026 3:13 am
Is your drive LibreDrive enabled? Upgrading my drive to LibreDrive made it work, before upgrading it was hanging. 1.18.3 on Debian 13.
xesegik
#7 Post by xesegik » Sun May 24, 2026 12:36 pm
Sounds like the same problem I am having. I just downgraded to 1.17 and it seems to work again. There are several other topics here about that. I think there might be a problem with 1.18 on Linux. Maybe even a MakeMKV-drive-compatibiliy issue? (I have no way to verify that though)
See also ...
tomty89
#8 Post by tomty89 » Sun May 24, 2026 7:09 pm
For the problem of 1.17.6/7+ not working with a non-LibreDrive (on Linux), the best workaround is probably the sdf_Stop setting. See e.g. viewtopic.php?f=3&t=41692
