Pioneer BDR-UD03 UHD possibility
fornax
Re: Pioneer BDR-UD03 UHD possibility
Post by fornax »
Coopervid wrote:
Mon Mar 16, 2026 7:09 pm
Post your Makemkv info after flashing. Did you follow the tutorial?
Yes, I followed the tutorial.
Laufwerksinformation
OS-Gerätename: /dev/sr1
Produzent: PIONEER
Produkt: BD-RW BDR-UD04
Revision: 1.14
Serienummer:
Disk-Informationen
Disk wird geladen
Disk does not load...
Makar wrote:
Tue Mar 17, 2026 12:10 am
I got lucky and bought the last Pio UD03 in the state at Staples :)
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Highest AACS version: 77
Drive platform: RS8511
Firmware version: 1.14
PM sent.
fornax wrote:
Tue Mar 17, 2026 6:17 am
Produzent: PIONEER
Revision: 1.14
Serienummer:
Disk-Informationen
Disk wird geladen
Did you remove all power to drive after flashing including the USB connection?
Migaman
Post by Migaman »
Coopervid wrote:
Sun Mar 15, 2026 10:34 am
PM sent.
Thank you!
JakaBasej02
Post by JakaBasej02 »
Good day/evening sirs, I am new and cannot send PMs, but I would like to flash my drive so that it can rip 4K BD, can anyone help me please? thanks in advance! Drive Information Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14
It's definitely worth getting that drive updated. The UD03 is a solid performer for 4K once the LibreDrive firmware is applied. Just make sure you double-check the revision matches the flasher requirements mentioned by the experts here to avoid any issues.
fornax
Post by fornax »
Coopervid wrote:
Tue Mar 17, 2026 1:23 pm
Produzent: PIONEER
Revision: 1.14
Serienummer:
Disk-Informationen
Disk wird geladen
Yes, I tried it several times, also with rebooting. The tested DVD works in my internal drive (which is not BluRay)
fornax wrote:
Tue Mar 24, 2026 3:32 pm
Produzent: PIONEER
Revision: 1.14
Serienummer:
Disk-Informationen
Disk wird geladen
Most likely a power issue since these enclosures are very power hungry. Try an USB-C port , use the rear USB-C ports of a desktop or a powered USB hub.
mushiness
Post by mushiness »
Turns out a drive I've had laying around for years is a UD03, could I get the 4K compatable firmware as well? Also, at the risk of being a choosing beggar, is Windows still a requirement to flash the drive? I can work with that if need be, but I'd prefer to use either Linux or MacOS.
Revision: 1.10
Serial number: QHDL087083WL
Firmware date: 2017-04-18
Firmware version: 1.10
rembyx
Post by rembyx »
Hello! I'm trying to upgrade my drive to accept UHD if it's possible, any help would be much appreciated:
OS device name: E:
Revision: 1.14
Serial number: DGDL539020WL
Highest AACS version: 82
wimun
Post by wimun »
Hello! I'm new here :) I need help with the correct firmware for my Blu-ray drive Asus SBW-06D5H-U,
which is identical to the PIONEER BDR-US03
OS-Gerätename: \Device\CdRom0
Produzent: ASUS
Produkt: SBW-06D5H-U
Revision: E101
Serienummer: THDL188128WL
Firmware-Datum: 2018-08-22
Firmware version: E101/ID26
wimun wrote:
Sat Mar 28, 2026 4:31 pm
Produzent: ASUS
Revision: E101
rembyx wrote:
Sat Mar 28, 2026 3:45 am
OS device name: E:
Revision: 1.14
mushiness wrote:
Thu Mar 26, 2026 9:29 pm
Revision: 1.10
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
pebkac87
Post by pebkac87 »
Hello new user. Just picked up a Verbatim 43888 that is a pioneer drive. found this forum to update to be able to enable 4k disks for MakeMkv. Any help would be great. Thanks
Revision: 1.14
Serial number:
pebkac87 wrote:
Mon Mar 30, 2026 6:22 pm
Revision: 1.14
Serial number:
PM sent.
Revision: 1.14
Serial number:
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
pebkac87
Post by pebkac87 »
Coopervid wrote:
Mon Mar 30, 2026 7:23 pm
Revision: 1.14
Serial number:
PM sent.
Thanks for the patch. I was able to flash my drive and now able to backup my UHD disks to my plex server.
Donation sent.
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DDDL526288WL
Drive platform: RS8A10
