Unable to rip disks to Truenas server on the network
Tonytitan
Post by Tonytitan »
This is me putting my ignorance on display.
I have a Truenas server for movies set up on my network. I am running Ubuntu 24.04 on my go-to PC. Sharing to my folders where the movies reside is enabled. No problem playing movies thru Kodi. When I rip disks saving them to the Truenas server is either not an option or I'm misreading what I'm being presented with. Unconfuse me, please!
Re: Unable to rip disks to Truenas server on the network
If you take MakeMKV out of the equation, can you copy a file to your NAS via the same shared folder you're trying to use with MakeMKV?
Tonytitan
Post by Tonytitan »
Copied a file from my home folder into Share_1 folder on my NAS. So yes, copying happens.
Personally, my workflow is to work on a local SSD-based scratch space and push my output to my NAS after I'm finished with it. Lots of users on the forum seem to set MakeMKV's output location to a mounted shared folder on their NAS however.
In MakeMKV, when you're picking an output location can you type in the fully qualified path to your shared folder?
I'm not sure I understand where you're getting stuck, probably because I don't have a lot of experience with this particular workflow.
