No Disc Error for Lawrence of Arabia 4k Disc 2
flav200060
#1 Post by flav200060 » Fri Feb 20, 2026 4:58 pm
First time posting here. I have been using MakeMKV for a while now, but this is the first time that I encounter an error which I cannot solve.
So, I just bought Lawrence of Arabia in 4K (in france) from editor ESCD.
I had no problem ripping the first disc, BUT ... I threw the second disc in my drive and saw a "No disc inserted" within a few seconds (maybe 20 seconds).
So I take it out, clean it up, try again, and ... same error.
I usually have no problem ripping 4K UHD discs, this is the first time this happens to me, so I think "Maybe it's the disc". So I go back where I bought it to get another copy. I test the Disc 2 and ... same error. Disc 1 also works on this copy, the 1080p blu-ray works fine too. So, it may not be the disc, nor my drive.
Does anyone have any idea what could be going on with this ? I am missing something or am I stuck to ripping in 1080p only ?
Here are some technical details about my drive:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 82
Drive platform: RS8D31
Firmware version: 1.03/ID05
And the debug logs (not very useful I think):
Debug log started at Fri Feb 20 16:44:41 2026 , written by MakeMKV v1.18.3 linux(x64-release)
001005:0000 MakeMKV v1.18.3 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///home/*/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.5.0/OpenSSL/3.0.13/1.59.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at `BLLaJX7%0; ?J)zOB:`KC:29393631
SDF v0a5: PIONEER_BD-RW__BDR-XD07U_1.03_BDDL004126WL
Thanks for the help !
splendid_alex
Re: No Disc Error for Lawrence of Arabia 4k Disc 2
#2 Post by splendid_alex » Tue Mar 24, 2026 11:28 am
I have the exact same issue on a different Pioneer drive. I got a replacement copy sent to me and that had the same problem. The drive spins up, doesn't make the usual read/seek noises, then just ejects the disc.
Not sure if there's anything we can do but this is the first and only disc I've had this with.
Info:
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.01
Serial number: BBDL005550WL
Firmware date: 2020-09-03
Drive platform: RS8E21
Firmware version: 1.01/ID05
