Issues with Tom and Jerry Anthology
Stryker412
#1 Post by Stryker412 » Tue Mar 24, 2026 12:36 am
I just picked up the Tom and Jerry set on sale. I cannot open the disc in MakeMKV on either of my BD drives. First time I've ever seen the "Failed to Open Disc" error for any title. Has anyone else had issues?
Re: Issues with Tom and Jerry Anthology
#2 Post by dcoke22 » Tue Mar 24, 2026 1:13 pm
Have you tried gently cleaning the disc?
If on Windows it is often recommended to let the OS see the disc first then open MakeMKV.
Stryker412
#3 Post by Stryker412 » Tue Mar 24, 2026 10:05 pm
I just tried again after cleaning the disc. Should I process a return?
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00055.mpls has length of 340 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01307.mpls has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00010.mpls has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00120.mpls has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00140.mpls has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01065.m2ts has length of 19 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01070.m2ts has length of 23 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01071.m2ts has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01072.m2ts has length of 340 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01073.m2ts has length of 50 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01074.m2ts has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01075.m2ts has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01076.m2ts has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01086.m2ts has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01066.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01063.m2ts has length of 5 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01007.m2ts has length of 13 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01210.m2ts has length of 87 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01156.m2ts has length of 552 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00253.m2ts has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01211.m2ts has length of 541 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01212.m2ts has length of 520 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01213.m2ts has length of 494 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01214.m2ts has length of 476 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01215.m2ts has length of 447 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01216.m2ts has length of 480 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01217.m2ts has length of 470 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01218.m2ts has length of 474 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01219.m2ts has length of 488 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01220.m2ts has length of 451 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01221.m2ts has length of 479 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01222.m2ts has length of 427 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01223.m2ts has length of 432 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01224.m2ts has length of 444 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01225.m2ts has length of 424 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01226.m2ts has length of 445 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01227.m2ts has length of 444 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01228.m2ts has length of 492 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01229.m2ts has length of 424 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01230.m2ts has length of 440 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01231.m2ts has length of 458 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #01232.m2ts has length of 22 seconds which is less than minimum title length of 600 seconds and was therefore skipped
#4 Post by dcoke22 » Tue Mar 24, 2026 10:41 pm
I don't have that blu-ray so I'm just speculating. It looks like MakeMKV skipped every title on that disc because they're all less than 600 seconds (aka 10 minutes). What happens if you adjust your settings to a smaller minimum time?
Stryker412
#5 Post by Stryker412 » Tue Mar 24, 2026 10:48 pm
Oh geez... I'm so used to ripping full TV episodes. That's embarrassing.
